All questions need 'year make model', and please don't use 'text speak' abbreviations as it causes confusion to the more mature experts.
Generic Answer is 'No'! The reason is that functions like that are a function of the Body Control Module. If you disconnect that, nothing works. Fix the problem, don't try and find a way around it. In the old days, there were sounders, but now the BCM puts chimes though the vehicle audio system even if the radio is switched off!
Google
year make model emergency brake chime problem
https://www.google.com/search?q=%E2%80%8Byear+make+model+emergency+brake+chime+problem
Is there a way to turn off the parking brake chime in a 2017
JustAnswer
https://www.justanswer.com > Ford Repair
Jun 19, 2021 - Generally, you will release the parking brake before placing the transmission into gear which should prevent the noise.
1 answer · Top answer: I'm glad that I was able to answer your question today. My goal is to ensure you receive ...
Is there anyway I can turn off the chime for the electric
Sep 9, 2022
Parking brake is not on but when try to drive it makes
Mar 12, 2022
2017 Ford Edge parking brake light is on and the door chime
Aug 1, 2022
Parking brake fault and auto hold fault lights on. Parking
Nov 19, 2021
More results from www.justanswer.com
Chime and Parking Brake Light Comes On
Ford-Trucks.com
https://www.ford-trucks.com > forums > 1220889-chi...
Feb 1, 2013 - Ok, on my 06 250, my parking brake light comes on and with ding. ive checked the brake fluid, its maxed out, i have no lose of braking power ...
Emergency brake light/beeper won't stop-- driving me crazy!
Riviera Performance
https://rivperformance.editboard.com > ... > Interior
Jun 15, 2009 - Test: after checking the fluid level, try engaging the parking brake while rolling about 25 mph (you can disengage while moving). The brake ...
Emergency Brake Light and Ding
Diesel Place
https://www.dieselplace.com > threads > emergency-br...
My emergency brake light is on and a warning chime rings even while driving. The brakes are working as is the electric brake. Chime goes with or without...
