Palm Treo 750 Smartphone Logo
a
abubakar ally Posted on Jan 01, 2014
Vodafone internet settings
It can not connect to the internet
2answers
I cannot connect to the internet in mobile. it says "No internet account has been set up. please set an internet account". it happends with all services like vodafone,Aircel......
ask your service provider for internet settings after that only you could connect to internet.
for vodafone snd VODAFONE TO 52586 FOR SETTINGS. do inform me if the prblm is solved. good luck
Aug 31, 2011 • Cell Phones
4helpful
2answers
How internet setting in my samsung s3310i model
If you are a vodafone customer then first of all you must activate your vodafone number just sending an sms ACT VL to 144
Then go Menu->Setting->Application->Internet->Internet Profile->select Vodafone GPRS/Vodafone live.
Good Luck.
Thanks
Feb 03, 2011 • Cell Phones
2helpful
2answers
LG KS360
Internet settings are usually found under the Phone Settings – Internet Settings.
- Connection mode Connection orientated / permanent / continuous connection
- GPRS APN live.vodafone.com
- Homepage URL http://live.vodafone.com
- GPRS ID username "none required"
- GPRS password "none required"
- Port (if required by device) 8080 (some older handsets may require you to enter 9201)
- PPP authentication type PAP (default)
- Proxy authentication name "none required"
- Proxy authentication password "none required"
- Proxy login type automatic (default)
- Security Off
- WAP gateway IP address 172.030.038.3 (your phone may require 172.030.038.003)
If you phone is a Vodafone NZ supported handset you may be able to have this sent automatically to your phone.
Mobile settings for sending and receiving PXTs (MMS messages)
The PXT settings can usually be found under Message Settings - MMS setting. You also need to send a message before you can receive one.
- APN live.vodafone.com
- MMS server address http://pxt.vodafone.net.nz/pxtsend
- GPRS ID username
- GPRS ID password
- MMS automatic download On (Automatically downloads full MMS)
- PPP automatic download PAP (default)
- Proxy authentication username
- Proxy login type Automatic (default)
- Security Off
I cannot connect to vodafone live.
check the settings by going to menu-----settings---connectivity----internet settings---internet profiles. make sure that vodafone live is selected as the profile. after making the changes just restart the phone and now try.
hope this will solve your problem
2helpful
Vodafone live and internet settings
Hi Emma,
Have you tried contacting Vodafone customer services? they can send you a settings from their network very quickly.
By the sound of it, you just need to create a new connection, if you can go to the settings look to make a new one.. call it My isp or something if it asks for username password - leave them blank or type "web" for both username and password. Try connecting to that connection only and the browse vodafone live.
let me know how it goes;
Thanks.
Nas.
4helpful
3answers
GPRS settings for htc3400i with vodafone live
vodafone live setting for windows based mobiles version 6::::
select "start" ---->>> select "settings" ------->> select "connection"----->>> select "connections"
Now Select "Add a new modem connection"
Connection name::"Give any name"
Moden:: select "Cellular line (gprs)"
Select "Next"
Access point name:: "portalnmms"
select "Next"
Username:: (blank)
Password:: (blank)
Domain:: (blank)
Select "Finish"
Now Select "Setup/Edit my proxy server" below that "Add a new modem connection"
Select the two check boxes
1.) This network connects to the internet
2.) This network uses a proxy server to connect to the internet
Now you ll have proxy server box below that you will have "advanced"
Select "advanced"
Select "HTTP" --->> Server:: "10.10.1.100" port:: "9401" select "ok"
Select "Wap" ---->> Server:: "10.10.1.100" port:: "9201" select "ok"
Give ok to all options.
Now select "start" select "internet explorer" and try it for the connection...
When internet is connecting it ll show "Connecting to GPRS"
You ll be getting "locating" and "opening" and the webpage
31helpful
5answers
How to activate vodafone live india in HTC touch P3452?
Select "Next"
select "Next"
Username:: (blank)
Password:: (blank)
Domain:: (blank)
Select "Finish"
Select "advanced"
2helpful
4answers
I CAN'T SEND AND RECEIVE MMS MESSAGES
call the company who your sim card is with, and they will give you settings to setup MMS (and internet access if required).
it needs to be setup through them!
Top Palm Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
vince
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
