Jenn-Air JCD2295KES Stainless Steel Logo
Posted on May 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ice maker overfill
The icemaker on this unit has overfilled the bin since day one. The ice spills out onto the dispenser drive housing at the back of the bin. There is no guidance in the install manual for this problem.
Thanks
Anonymous
Level 3:
  • Jenn-Air Master 3,361 Answers
  • Posted on May 20, 2009
Anonymous
Jenn-Air Master
Level 3:
Answers
3361
Questions
Helped
1029820
Points
10654
The metal off/on arm may be disconnected. A full bin should keep the arm in the up position and shut off the ice maker.
Remove, then re-insert the metal arm in the back of the ice maker control head.
Make sure that a full bin of ice activates the control arm.
You may need to buy a replacement arm that is longer so that the ice catches on the arm.
1helpful
My icemaker is overfilling water.
Find the manual for the ice maker - it may be in an envelope on the back of the refrigerator. Inside, there should be instructions for setting the timing for the water fill valve. Your water fill valve is open too long, reduce the open time for the fill valve.
Ice maker not working
my icemaker has a wire overfill sensor which shuts off the icemaker if there is too much ice in the basket. If this wire gets pushed up it will stop making ice until level lowers OR manually lowered.
1helpful
Icemaker drips after refill
Good day,
The ice maker has a switch internal, that turns the water valve in the bottom rear of the machine on for 7 seconds after it harvests a batch.
That valve must close smartly, otherwise it will cause the cavity of the ice maker to overfill, and cause it to overfill.
If it does harvest cubes, then that is your problem. Replace the water valve. It's a very common problem.
Thanks for using FixYa
The icemaker in my freezer has a slow drip. The water then freezes in the ice bin. Why is it dripping, and how can I fix it?
Good day,
The most common reason is the ice maker is overfilling because the water valve in the bottom rear of the refrigerator leaks on the off cycle, and needs replaced.
Make sure the machine is level and the ice maker is mounted in the freezer properly to keep it level.
Also, make sure the fill pipe going into the back of the ice maker is properly positioned.
The Ice maker body could have failed but is very rare.
3helpful
Ice maker overfills and leaks into the ice bin.
I have had a similar problem several times. What I have found is that the ice tray coating has begun to flake off. Then, the ice sticks or partially dumps. Next more ice builds up and when the valve opens the water runs over the partially emptied tray and spills into the bin making "icebergs". The remedy is to replace the tray or if that is not possible, then, the whole icemaker. In fact, I have one down stairs to put in tomorrow. They don't seem to last more than about 4 years or so.
Ice Maker overfilling with water
you may have abad water valve or icemaker
Ice bucket/bin frozen in place
mine was overfilling because the ice was getting stuck on the way out. So some stayed in the tray and when the water would refil, it would overfil and go over the stuk cubes. leaving it to overflow to the bottom and freeze like yours.
2answers
Ge top freezer refrigerator ice maker problems
most likely bad icemaker but could be a leveling issue or overfilling which both would be very noticable
Top Jenn-Air Refrigerators Experts
john h
ZJ Limited
ZJ Limited
Jose Ramirez
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
