Its hard to get the tv on but after a few attempts it will but no sound unless it warms up for 15 minutes or so. however after a very short time there is a loud electrical pop noise and we lose the pic but the power indicator light stays green. what could be the cause and is there an easy fix?
SOURCE: No screen display - VIzio 50" Flat screen TV
If you purchased the TV 6 months ago, still under manufacturers warranty. They normally give customers 1 year warranty coverage.
It looks like the main board will have to be replace on this TV or fix to the component level.
SOURCE: VIZIO 42" Plasma HDTV
i have a vizio p42 and i have sound but no picture i have tryed to reset it but nothing works
SOURCE: Vizio model no.P50HDM, loud pop then no picture. Green pwr ind on
P50HDM, loud pop then no pic...
SOURCE: TV looses picture and sound. Will not turn back on
www.plasma-television-repair.com/Sample-Preview-Plasma-Tv-Repair-Training-Manual.pdf -
Above is a training manual, this should help you find and fix the problem if you wish to DIY. If you DO, decide to DIY, you MUST MUST get a Service Manual, for your exact make & model. it will be similar to the Training manual, but explicitly for your set.
I do not recommend it however.In my professional opinion, you should contact Vizio and ask for an approved local service center, then, get a "Quote" for repair.
With faults such as this, it is important to leave them disconnected from the wall, as it is entirely possible, for a faulty, TV, to cause a fire, an explosion, or both. Anytime one hears any sort of "pop" similar or not, is grave cause for concern, as usually this means some sort of component failure, in a high voltage area.
SOURCE: vizio gv47l lcd a popping sound and tv when dark and no sound
This sounds like a main board issue to me.
