You will have to set-up using your router. Please use the following source:
http://www.wikihow.com/Setup-D-Link-WBR-2310-Wireless-Router
hope this helps and please don't forget to rate.
SOURCE: Is there a WPS button,
http://www-security-camera.com/d-link-dcs-930l-mydlink-enabled-wireless-n-network-camera/
This is a "plug and play "device ...and all you have to do is to open it and let it find the network ..and after that will be visible in your network places folder...and a device ..
if you want a more advanced control you should install the software that came with it ...
It may be necessary to change the security and remove the password while connecting ...or ..if you have a mac access set to the router ..add the camera's mac to it ...
It is supposed to find the network and connect to it auto ..once you enable the wireless connection on it ..
Also if you preset the IP range in the router ..you may need to enlarge it so that the camera 's IP to be in that range ..but Im not that sure about that ..cause it is a wireless device and it may have no issue of that kind..Just take a good look at it ..cause it probably has a button you need to enable for instant auto access ...
SOURCE: i have a d-link wbr-2310,
On the iPod touch, select "Settings"
On the second line, you should see "Wi-Fi", touch on the right side of this bar, this will bring you to the menu to choose a network. From there, choose the network you want, and type in the security code if need be.
As a note, if you go back to settings, the 1st line is "Airplane Mode", make sure this option is "OFF".
SOURCE: I'm trying to connect a
There is no WPS button on the WBR2310 router. Simply connect to it like you would any other device, such as a computer.
