Health & Beauty Logo
Posted on May 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Measurement definitions Does anyone know what the healthy ranges are for the bone mass and muscle mass measurements on the Taylor body fat analyzer scale (or where to find these)? This information is not included in the manual nor displayed on the screen. Thanks!
Anonymous
Level 2:
  • Expert 122 Answers
  • Posted on May 20, 2009
Anonymous
Expert
Level 2:
Answers
122
Questions
0
Helped
33980
Points
204
How do I obtain the bone,muscle,hydration,fat and calorie measurement on a dquip body fat/hydration monitor scale (infrared transmission body fat scale) I see the weight on the scale Bella
These measurements are based on BIA (bioelectrical impedance analysis). As you stand on the scale, you stand on electrodes, which generate small electric impulses which pass throughout your body (and different tissues of course). Different tissues have different electrical conductivity and resistivity due to their different hydration (e.g fat tissue contains very small % of water, that's why its resistance is high), so the scale measures the % of different tissues in your body by analyzing the resistance(this analysis is quite complicated and not very accurate).
Eat Smart scale showing body fat as much too low
Probably there's a build-up of skin oil from your feet that is preventing it from reading properly. Clean off the top of the scale with a cloth dampened in soapy water, then rinse wipe it with a cloth dampened in plain water, and dry it. Be careful not to dribble liquid into the scale.
Note: fat measurement by this method is difficult to do accurately and consistently, For best results, make sure you're properly hydrated at least ten minutes before measuring, and wash and dry the soles of your feet first.
2answers
What is mean by body mass index?(bmi)
Is a measurement to determine a persons weight over height the formula is weight(KG) / height(METRES), a normal healthy person should have a bmi of 18.5 to 25 anything above this means the person is fat to obese
3helpful
What do the number mean on Curves Plastic Body Analysis Scale?
F = Body Fat
W = Water
B = Bone Mass
M= Muscle
1helpful
2answers
Male/female image on scale:which?; normal muscle mass/bone mass range
The tiny triangle in the shape of a dress is female; the tiny triangle with the broad shoulders is male
What does BIA value of 38% mean?
The BIA is bioelectric impedance analysis or your body fat. BIA is the method used to determine your body fat, it sends a small electric pulse through your body and using formulas that account for the time it takes for the pulse to travel through water, muscle and fat. Remeber that this measurement can be affected by different variables such as water if you have taken a shower or drank a glass of water before being measured so it is not always acurate. To obtain a more accurate measurement I reccomend using it first thing in the morning before showering or eating/drinking when there is less chance of variables. Please let me know if you need further help :) Have a great day!
3helpful
What do the three numbers represent? Weight is obvious, but "f" and then the last one?
http://www.conair.com/instruction_booklets/06AD15055%20IB%20TH313.pdf
I think this is the manual for the above mentioned product. Does it say f or BF? BF is % fat with in your body, although the techonolgy used is not too acturate, you can use it as a guide, to ensure the best possible acuracy be sure to use it at the same time of day preferably before drinking or bathing/showering. Usually first thing in the morning after you use the rest room is best. It uses electrical impedence to measure for the extra measurement features and these factors can skew the readings.
H20 would be water content, and
bone is bone denstiy which is important to keep take of espicially if you are an older female, or on medications that affect bone density. Although i am not sure how acurate the readings would be and highly reccomend if you are at risk for ostioparosis or any other diseases or on medications affecting bone desinties to check in with your doctor about testing and monitoring.
11helpful
E3 Error
here are the codes i found
E-1 Electrodes were not firmly grasped. Grasp the electrodes correctly.
E-3 Hands are dry. Slightly moisten hands with
a wet towel.
E-4 Body Fat Percentage and BMI values are outside themeasurable range. verify your personal data is
correct.
E-5 and E-6 Irregular Operation Turn the unit off, then on. Take another measurement. If the error occurs again contact Customer Service at 800-634-4350
have a great weekend!
1helpful
BF% is wrong
Unfortunately, it's the scale, but it's not broken. It simply is telling you inaccurate information.
Some scales utilize Bioelectrical Impedance Analysis (BIA) technology. BIA uses very low levels of electrical impulses running from one metal contact point/lead to another. Your body acts as the connector between the two contact points, thus completing the circuit. Not all scales use this means for calculating body fat percentage due to poor reliability and high fabrication costs.This method of measurement requires very large contact points, as well as clean and moist skin exposure. If you have dry/calluced feet, which is normal for most Americans, the sensors can not accurately measure due to skin resistance. Dry skin acts as a resistor to electrical impulse. Electricity passes through muscle and fat at different rates. However, its measurements may be thrown off by how hydrated you are and how much you've eaten; it may be too inaccurate for anything other than comparative use. Users are encouraged to establish a baseline measurement and repeat measurements under consistent conditions over time to detect changes.
Many less expensive models simply use a body-fat calculator to average your imputed height in inches, waist measurement in inches and the current weight measurement recorded in lbs. The scale compares your measurement with the ideal norms inputed during the manufactoring process, thus giving you a comparison vs.imputed norms. People who are very, very fit can get numbers 3 to 5 percent higher than their true percent body fat. Because they don't have a lot of fat inside their muscles(visceral fat), the simple tape measure calculation test cannot adjust as it should indicate.
Conversely, if a person is skinny but not fit, this body fat test may yield a number 3 to 5 percent lower than his or her true percent body fat. Though they look thin, unfit skinny people really have more than the usual amount of fat inside their muscles, which you can't see from the outside.
In either case, the scale is not necessary a measurement tool, due to high variables of test inaccuracy and interuser reliabilty; but, it is a good tool for comparing whether or not you are gaining/losing body fat.
If you would like a more accurate tool for simply measuring your body fat, you can pick up some pinch-calipers online for about the price of a scale. They come with an instructional pamphlet, very easy to use.
Top Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Health and Beauty Expert? Answer questions, earn points and help others
