Two year old LG Tromm stackable washer. Error code on "FE" and continues to fill. Turned off machine, was able to get it drained and cycled through but next load same "FE" error code. Can you direct me to restart? Thank you, Sheri Tucker Culinary Arts La Quinta High School La Quinta, CA
Hello Sheri Tucker,
The "FE" code is referring to a bad or malfunctioning water valve. The machine continues to fill because the solenoid on the valve inside the machine isn't closing to stop the water. The valve should be inspected and/or replaced if bad. This will require some dis-assembly, if washing machine repair isn't something your comfortable with then a service call is the best bet. If you are going to try and inspect yourself please make sure you unplug the machine before starting any dis-assembly. Hope this helps.
Thanks,
edgin96
I’m happy to assist further over the phone at https://www.6ya.com/expert/ryan_7b238a1b08d97b98
You can switch the 2 left solenoid connections blue and white which is main wash and per wash, and if you only use the hot wash cold rinse selection it will cycle normally. This is just a quick fix so you can wash till you replace the cold water inlet valve.
water starts pumping in it doesn't stop.
when water starts pumping in it doesn't stop.
