WAS STARTING AUTO CLEANING AND A BUSSING CAME ON AND THE NUMBER F5 IS ON. iICAN'T OPEN THE OVEN DOOR.
Top oven door slipped off & can't reinstall
Resetting this switch solved my problem.
To reset it:
TURN OFF THE POWER!
Open the door (if it is locked, turn the power back on and gently pull on the door every few seconds as the locking mechanism cycles until it is unlocked)
remove the 3 screws below the control panel (screws point upwards, with the head just inside the oven)
pull off the face of the control panel. Let it dangle by the wires so that you have access to the space behind it.
Within the electrical enclosure exposed by removing the control panel, Look for a small silver and black device with 2 wires attached to the back. The device is about .5" wide by 1" long and is attached with 2 screws to the sheet metal on the bottom of the electrical enclosure. Mine was located nearly in the middle of the electrical enclosure.
Push the tiny button on top of the switch. You should fee a click.
Replace the solenoid.
Make sure that the oven door is closed when you start the Self Clean cycle. Check the door switch to see if it is apparently operating properly. Open the oven door and the oven light should turn on. Press in the door switch plunger and the light should turn off. If the light switch is not operating properly, it could cause this type of problem.
If the light switch is operating properly, then you could have a failed door latch assembly. A wiring failure or a problem with the control board could also cause this failure. I recommend that you unplug the range and access the door latch assembly at the back of the range. Pull the upper and lower back panels off of the range. Caution: The edges on these panels can be sharp. Protective gloves are recommended. With the panels off, check the wire harness connections on the door latch assembly.
During cleaning, "cool" was on then panel went black and door will not open.
------ thanks----
oven door locked displaying loc
My EB876-6 oven door locked. It was not in the cleaning process nor had I just used it....it just locked up and wont open.
tried cleaning upper oven but clean, door and oven light blinks and lock makes a sound then error comes on
upper oven getting error message E9 does not turn on
