The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size
SOURCE: problems with my 50 inch hitachi ultravision projection screen tv
check the solder around the area of the vertical IC. solder is either cracked or else cold. Cold solder appears as dull. Resolder anything that isnt shiny.
SOURCE: 50 inch Hitachi Ultravision LCD Rear Projection Television
Hitachi has had problems with their light engines. Very expensive. Contact Hitachi as they may give you consideration even if this is out of warranty.
SOURCE: Rear projection HD Hitachi Ultravision always has greenish tint
This is what you're going to do, Turn on the Tv and go to the service manual, if the green tint is still there, you have a defective dmd board, but if it's no there, then you have an issue with your video board
if the power button is blicking red then most likely ur lamp needs to be replaced. they dont come cheap but its an easy fix ...try ebay for the part ...and make sure u get the correct seze and watt for that specific tv ....on a side note...if u replace the bulb yourself....wear latex gloves and DO NOT touch the bulb. the oils on your skin will magnify the light and can cause that bulb to explode or pop and then u will be right back at squareone
SOURCE: I have a Hitachi SBX Ultravision 50" rear
This is a very common problem on your Hitachi model and an easy DIY fix. You can get the correct parts and instructions for this exact fix on www.TvRepairKits.com
Hi Angela Jones, This is a vertical output problem and knowledge of components , soldering and meter testing is required.
