I HAVE A KDE6500X/E/T KIPOR POWER GENERATOR. THE PROBLEM IS WHEN I TRY TO RUN THE ENGINE WITH AIR CLEANER ON THE ENGINE STALLS. BUT ENGINE RUNS WELL WITHOUT THE AIR CLEANER. I HAVE TRIED TO CLEAN THE AIR FILTER ELEMENT THE RESULT IS THE SAME, WHAT COULD BE THE PROBLEM?
This means that you are over fueling. There is more fuel going to the carberator than air. By removing the air filter you are allowing more air flow into the carberator, which is allowing the engine to run right. Natural gas and propane generator must have no more than 11 inches of water column. Gasoline engines should have no more than 3.5 psi out of the electric pump. If gasoline is gravity fed, then this means that you need to rebuild the carberator or purchase a new carberator, but try to adjust the flow valve on the bowl of carberator first.
