Is your Canon printer experiencing an error? Sometimes a quick reset is all the unit needs to remove problems. To Hard Reset Canon Printer Error, you will have to run a power cycle, reset , or run a hard reset. Resetting helps in exterminating a stubborn error code or another problem that between the printer and the . It the printer queue and restores the factory settings for a fresh start. the reset with fresh ink cartridges if required and make sure the is you can contact Canon Printer Tech Support for receiving hand to hand remedy at your door-step.
So what does the error code allude to? Lens? software? Connections? Unless you know what the code stands for how you or anyone be expected to fix it?
SOURCE: what to do with canon
Try to replace the cartridge with a new one original canon,not refill or compatible.
