Stove making a clicking noise all of a sudden even in the off position
SOURCE: I was cleaning stove top
IWAS TOLD TO DRY IT OUT WITH MY VACUUM BLOWER WHICH DID NOT WORK THEN HE GAVE ME PLAN B.WHICH WAS TO COOK BREAKFAST EVEN THOUGH IT WAS STILL CLICKING AND THE HEAT FROM THE STOVE WOULD PROBABLY DRY IT OUT......IT DID AND IT STOP CLICKING!
SOURCE: GE profile gas stove igniter don't stop igniting
take a look at the igniter located in the center of two burners. clean the gap with a stiff brush between the eletrode and the upper plate. the distance is preset at the factory. you may have enough buildup to close the gap enough to trigger the igniter.
SOURCE: Electric stove elements stopped working
Circuit breaker is tripped duel breaker 1 of them is tripped, maybe an electrical problem causing this.
SOURCE: GE Profile stove not working
If neither bake or broil ignitors work you must first verify voltage to the parts.
Most likely a defective electronic control.
SOURCE: Stove Ignitor makes tik tik sound and the sparks continuously
may be a loose wire on the spark ignitor ceramic or if you run via main electic it may be your spark generator
