Computers & Internet Logo
A
Anonymous Posted on Dec 30, 2013
Hide my ip - Computers & Internet
Ann Moroz
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 89 Answers
  • Posted on Sep 23, 2014
Ann Moroz
Expert
Level 2:
Mentor:
Answers
89
Questions
0
Helped
38373
Points
554
There are many ways to hide your real IP address but the most reliable solution on my mind is using vpn. This is safe and really secure. VPN masks your IP address and also encrypt all your traffic, so you are anonymous in the Internet.
Sahrzad VPN The Best VPN Service to Access Blocked Sites
priya
Level 1:
Scholar:
New Friend:
  • Contributor 87 Answers
  • Posted on Dec 30, 2013
priya
Contributor
Level 1:
Scholar:
New Friend:
Answers
87
Questions
0
Helped
9162
Points
99
You can hide your ip address using this software http://free-hide-ip.en.softonic.com/
You can also use Proxy server to hide your ip.This could mask your IP with a fake one. You can check whether your original ip address hided or not using this site IP-Details.com
2answers
How to change ip address
Method 1:
To release and renew your IP address:
Step 1
Go to "Start > Run" and type "cmd" (without quotation marks), then select "OK"
Step 2
Type "ipconfig /release" (without quotation marks) and press "Enter"
Step 3
Once the prompt returns, type "ipconfig /renew" (without quotation marks), then hit "Enter,"
Step 4
Last, type "exit" (without quotation marks) then press "Enter" to close the window.
you have a new ip address.
Method 2
It's simple to change the Ip-address..You can reset the modem or switch for a minute and the switch on it..Check the ip-address at Ip-details.com if your ip address changed .It's Dynamic ip address ....You can change it many times by resetting the modem...Before changing check your previous ip ,so that you can know the difference.This is will not work if your ip address is a static ip address...Static ip will not change even if you reset the modem.
Method 3:
You can use proxy server or hide ip address software to change the ip address...But it's not legal to hide ip address always..It helps to hide your ip address from hackers..So whenever you need you can hide ip..Don't hide ip address always .. You can also display your ip from Canada using proxy,even if you are in USA.
Hpow u change ip adres
Method 1:
Step 1
Step 2
Step 3
Step 4
Method 2
It's simple to change the Ip-address..You can reset the modem or switch for a minute and the switch on it..Check the ip-address at www.ip-details.com if your ip address changed .It's Dynamic ip address ....You can change it many times by resetting the modem...Before changing check your previous ip ,so that you can know the difference.This is will not work if your ip address is a static ip address...Static ip will not change even if you reset the modem.
Method 3:
You can use proxy server or hide ip address software to change the ip address...But it's not legal to hide ip address always.It helps to hide your ip address from hackers..So whenever you need you can hide ip..Don't hide ip address always.You can also display your ip from Canada using proxy,even if you are in USA.
When I click on my Hide IP NG icon, it says it is updating and then it says that there was a download error and then goes to silent update and doesn't work?
Uninstall the Hide IP software and download a latest updated software and install it. To ensure that your newly downloaded Hide IP software really works, Visit www.ip-details.com and have an IP lookup. Good luck.
55helpful
2answers
Hide ip easy wont uninstall
Go in to Local Disk, and find Hide ip easy folder (within program files or program file x86) once found the folder, enter the folder and delete the icon with the same logo as hide ip easy, once deleted, Uninstall the file via control panel good luck
2helpful
Silent update Failed of Hid IP NG
hello
i have hide ip ng 1.6 program.
get silent update 2 failure message, can u solve my problem? it says that i need to exclude a program from the firewall. I did but the same happened again. I turned off the firewall and the same happened! please help
2answers
How can i make my ip address not shown
It is not possible to hide your IP address. Your external IP address is needed to allow traffic to the internet to get to and from you.
Within your local network, again the IP is necessary for traffic to get to and from you.
There is a lot more to it than that, but thats the basics.
1helpful
I want serial key the hide your ip address product
Such software products do _NOT_ work -- your IP-address is needed so that any "responses" to TCP/IP packets that you "send" can be delivered "to" your IP-address.
How to hide ip-address,find ip-address?
Well you cant hide ip address. But you can use a proxy server that well mask you ip.
and to find your ip you can goto http://www.ip-adress.com/
1helpful
Want to hide my IP
Unfortunately, it is not technically possible to always hide the public IP address of a home network. An IP address enables devices to locate and communicate with each other on the Internet. Completely hiding the IP address of a device would render it invisible but also unusable online. On the other hand,
It is possible to hide public IP addreseses from most Internet servers in most situations. This method involves an Internet service called an anonymous proxy server.
Grand Canyon Tech
Grand Canyon Tech
