It will drive the speakers but not the subwoofer. U need to connect the subwoofer pre- output from your amplifier to another amplifier that will drive the subwoofer.
If you connect the subwoofer directly to your amplifiers speaker output it will force the subwoofer to play the entire spectrum of frequencies (not designed to do that) consequently causing damage to the sub and maybe even the amp. So use the sub pre out.
hope this helped
....andy....
SOURCE: hifonics brutus 2000 watt help??!!??
If an RCA took a dive your amp has most likely seen a very nasty input spike and may never be the same as its circuitry has been damaged.....sorry
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
SOURCE: JL audio 250/1 not powerful enough for pioneer TS-W307D4?
you should move up to more power....underpowering subs is bad! try not to go under the subs rms by 5o watts?
SOURCE: my amplifier keep clipping
start with the lowest settings on all the adjustment knobs and turn your radio up to about 3/4 of the volume and go from there
SOURCE: How do I hook up my infinity 1600a at 2ohms with 2 4ohm speakers?
Placing the speakers next to each other face down, you will notice that the connection points run in sequence +- and +-. Now connect the - (negative) from the one speaker, to the + (positive) of the other speaker. Now connect the open + from the one speaker and the open - from the other speaker to your amp. Your amp should have a bridging indication. On the connection points of the amp, you should see a mark pointing to the first + and the last -. That will be your bridge and thus utilizing the full potential of your amplifier
