Posted on May 19, 2009
Emerson AV50 says ''NO DISK''
My combo Radio/DVD player (Emerson AV50) all of the sudden wont recognize when a disk is in the slot. i played a movie last night, fell asleep, and when i woke up the connection was lost. i checked all wires but found nothing wrong. Radio works but when you put in a disk it says ''NO DISK''
Anonymous
Level 1:
  • Contributor 40 Answers
  • Posted on May 19, 2009
Anonymous
Contributor
Level 1:
Answers
40
Questions
0
Helped
18080
Points
94
Hi, sounds like you have a dirty laser eye on the DVD player. The eye gets dirty and it won't read movies or function properly. I would recommend a DVD Cleaner CD. I would have you try this before I have you open the DVD Player to clean the Laser Manually. Please try this and Post the Result for me to Review. Thank you
2answers
My emerson ewr20v4 plays cds with music but not dvd with movies. It keeps displaying disk error
check and see if the dvd player needs to be cleaned. you can pick up contaminates from other dvd's or cd's get yourself a dvd disk cleaner and run it thru seveveral times . and try to play your money then.
1helpful
2answers
Dvd player wont play
Make sure that the DVD Disc is of the format that your DVD recorder can read. For example, if your recorder specifically requires a DVD -R type disk, it will puke on a DVD +R disk.
Memorex dvd-r 16x wont work
It could be the dvd there is different types of dvds that some dvd players cant use.
Emerson EWR20V5 DVD Recorder/ VCR Combo
didn't realize had to finalise the disc after recording.
Dvd wont work again
I have a emerson DVD recoder and VCR combo. I have the right disk but it keeps giving me the message can't recod on this disk. I can't figure out what to do? Can anyone give me any suggestions please.
2answers
Playing recordable dvd
My Emerson won't play anything except DVD Movies, never has, wasn't suppose too. Make your movies in DVD Video format and it will read them fine (unless it's broke). I make movies all the time and play them back in mine. It reads DVD-R, DVD+R, and in duel layered. It will not read RW disks!
Man I've every problem you can imagine with DVD Players. I've found when the disk gets stuck, as long as it's not jammed. You can turn the unit off or unplug it. Plug it back in but DON'T TURN IT ON! Instead hit the eject button and the drive should open the drive without trying to read the disk.
3helpful
4answers
Samsung DVD-4600 DVD/VCR Player
My Smasung DVD/VCR Combo stopped reading DVDs because of a dirty read head. It started by only playing disks sometimes, and progressed to never playing disks. I assumed it was a dirty laser lens so I bought a lens cleaner set. Unfortunately my player wouldn't play the cleaner disk.
So I took it apart and cleaned the laser lens manually with some isopropyl alcohol (the clenser that came with my cleaning disk), and a lens cloth (that came with my glasses). Just open the case (starting with the screws in the back) and remove the snap in cross panel that obscures the lens of the DVD portion. Put a drop of cleanser on the lens and gently wipe it with the cloth.
Oh and by the way, I take no responsibility if you break your own player while following my instructions. My own DVD player was far out of warranty at the time I cracked it open.
2answers
No playback
The dvd player does not recognize discs above 2x. I contacted Emerson, they have a software upgrade they will send you for free, but you have to ask for it. I think it gives the player the ability to read up to 8x.
Reads all but DVD-Help PLEASE
When you say it won?t read are you trying to play commercial DVD movies or read DVD data disks? If you're trying to play movies then you need a couple of things the first being some type of player program. Real player works as does Windows media player but usually DVD drives come with a striped down version of PowerDVD or WinDVD. If you in fact have a player installed and when a DVD is inserted in your drive it doesn't play it may not be configured to automatically play DVDs. Try opening your player program and trying to manually play your DVD. Let us know if you have any success or if you need more assisted. If you do let us know what player program and operating system you have and any error messages that may appear.
Top Emerson Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
