https://www.mt.com > Editorial > Generic > Op...
PDF
2.1 Switching on and off. Switching on. ? Press . The scale conducts a display test. When the weight display appears, the scale is ready to weigh.
If your Mettler AG204 balance is not entering weighing mode and getting stuck in the software version display, it may indicate a software or firmware issue. To troubleshoot the problem, you can try the following steps:
Turn off the balance and unplug it from the power source.
Wait for a few minutes and then plug it back in and turn it on.
If the problem persists, try resetting the balance to its factory settings. Refer to the user manual or contact Mettler-Toledo support for instructions on how to do this.
If the issue still persists, it may be a hardware problem, and you may need to contact a qualified technician or the manufacturer for repair or replacement.
It's always a good idea to keep your balance calibrated and maintained to prevent any future issues.
The tolerance for a 1 gram weight on a Mettler PM-6000 F precision balance is 0.1 mg (0.0001 g). This means that the balance is able to accurately measure the weight of an object to within 0.1 mg of its true weight.
Problem could be either the applicator itself or the cable that connects the applicator to the unit. If you can, get an alternate applicator and try that.
