You Will need ? factory reset. Usually when its off press and hold power/volume up/home until you see the Android robot with an opened belly cycle trough the menu with volume up/down and select with ? quick press of power button
More than likely it is a hardware failure or loose internal cable (eg. Motherboard to screen cable). You can try a factory reset, but doubtful it'll work.
It may be trashed. Try calling the Customer Service Dept. You probably have lost all data that's on it unless you've kept an updated backup on the cloud.
If a factory reset is required. Press and hold both Volume buttons and the Power button simultaneously; an Android logo with an exclamation mark should appear. Press both Volume buttons at the same time to open Recovery Mode and use the Volume Up and Volume Down buttons to navigate.
I will give you the instructions to do a hard reset for the tablet.
Once you do this, you will lose all the data on it and will be just like you bought it. The process is listed below.
Press and hold both Volume buttons and the Power button simultaneously. An Android logo with an exclamation mark should appear. Press both Volume buttons at the same time to open Recovery Mode and use the Volume Up and Volume Down buttons to navigate. Select "Factory Data Reset", press power, choose "Yes" from the menu and press the Power button again.
Am having problem to open up my tablet, when i powered it the icons don't show up for me to unlock it.but it shows the wifi signal and the screen picture i put on.
Won't turn on. Only shows ! In battery symbol
androids door is open with the ! symbol and the words no command
hi i m mityah my tablet will not erboot
