Question about Kenwood KM305 Stand Mixer
I have a kenwood major mixer, model A717c. My beater broke off in the mixer and I cannot remove the broken piece..suggestions for removing? Or do I need a new gearbox or what? And where can II get one, thanks
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 26 Answers
SOURCE: broken kenwood mixer (major)
Please tell what happen with your Kenwood maybe can help from here .
or call this people
Kenwood Home Appliances (Pty) Ltd
1295 Clubhouse Street
Maraisburg 1709
South Africa
+27 (11) 4740153
Regards
Kenwood Chef Restore
Posted on Jan 22, 2009
DonC
SOURCE: can't remove beater kmix from machine. it's stuck!kenwood
Here's how to fix the stuck implement problem:
The implements each have adjustable heights. to adjust the height you need to loosen the bolt at the top with a 14mm spanner. If the bolt was loose when it was being used then it can get too short and not leave enough clearance between the bolt and the machine in order to push up and turn to release the implement. If this happens take the open ended spanner, grasp the implement and rotate the spanner clockwise (when looking up at the machine from below. Once the nut is loose rotate the implement until there is enough clearance to remove it normally.
Posted on Nov 18, 2011
I need a apart part for kenwood major a 171C. The shaft where the beaters connect to machine is broken cogs etc are fine
This is the only thing I could find in order for you to get parts...This is their phone number in UK..Kenwood Spares Distribution Centre on 0870 241 3653 If I uncover anything else I'll let you know...
Jun 27, 2012 | Kenwood Food Mixers
Kenwood chef a701 beater shaft is broke can i buy a new one
yes go to kenwood web site look for dealers who still support a701 mixers.
Apr 06, 2010 | Kenwood KM800 Major Classic Stand Mixer
Hi,we have an old kenwood chefette hand mixer with worn parts.
does anyone know how I could get the whisk beaters for a Kenwood A375? Was given mixer but no whisks!!
Jul 29, 2009 | Kenwood Food Mixers
K-beater is stuck on our Kenwood Chef and we can't remove it
I couldn't remove the K-Beater as when I tried to turn it the whole mechanism turned with it. I couldn't even remove the splashguard! I was going to take it to the Kenwood factory (a few miles from home) but then I thought I'd give it one more go and this is what I did...
  1. Next to where the K-Beater attaches in the middle of the circular plate is a lug with a pointed-shape bolt on the end. Remove this with a spanner and the beater plus gear cog can be removed.
  2. Place some mole grips or wide pliers on a worktop and sit the cogged gear in to it and grip so that it won't turn.
  3. Now you should be able to remove the K-Beater!
Perhaps someone can suggest how to stop it happening again. I haven't attached anything since but will update this post if I have any other helpful tips.
Feb 15, 2009 | Kenwood KM400 / KM410 Chef Classic Stand...
Broken kenwood mixer (major)
or call this people
Maraisburg 1709
South Africa
+27 (11) 4740153
Regards
Jan 07, 2009 | Kenwood KM800 Major Classic Stand Mixer
New Kenwood chef km 001 - I can't get the beaters out!
Try turning the beater in the reverse direction to the direction it normally turns - clockwise looking at the beater (I think), this should make the shaft pins ride up on some cams which should release the beater.
Sep 23, 2008 | Kenwood KM800 Major Classic Stand Mixer
Beaters fall down
You have to change the planet hub and the beater.
Nov 06, 2007 | Kenwood KM800 Major Classic Stand Mixer
Kenwood KM305 Stand Mixer Logo
43 people viewed this question
Top Kenwood Food Mixers Experts
Peter GW Fleming
Level 1 Expert
Treefrog15
Treefrog15
Yitz Diss
Level 1 Expert
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
