You could try re-calibration, or reset the device, or restore device factory settings as per the below 3 options. There is also a link at the bottom to a user guide. If that doesn't work, you probably have a faulty touch screen, in that case return the device to the place of purchase for warranty repair/replacement:
Q: G-SENSOR is not responding.
A: You should calibrate your device using 'Settings' / 'Display' or Gravity Calibration App (optional).
Q: My GOCLEVER tablet does not react well, it is freezing, works much slower than normal or does not respond at all.
A: We recommend to restart your device using turn on/off button (pressing 3-4 sec) or reset button (with a pointed object).
Q: How do I restore factory settings?
A: You should use 'Factory reset' function available in the 'Settings' App. The factory reset will help if your application causes the inappropriate operation of your device. Note, that all your files will be lost, so we suggest to copy them to another device (pendrive, PC etc).
http://1palladium.com.ua/load.php?f=goclever-terra-101.pdf
