I have a Dell Vostro 1700 notebook running Windows XP Pro with blue screen error message: STOP: c0000135 {unable to locate component} This application has failed to start because user32.dll was not found. re-installing the application may fix this problem. My computer will not boot up, I have tried booting into Safe Mode to no avail, it still keeps rebooting; I tried booting into the last known good configuration and that did not work either.
SP2 and SP3 has been installed some time ago with no problems. The computer has Anti-Virus AVG & Spyware Doctor installed. Put the Dell XP application CD in the drive (not the Windows XP reinstall disk) and tried BOOT LOGGING via the safe screen, but get the same message. BIOS is the only access.
During startup, just before the Windows splash screen appears, you should be able to hit the F8 key for a list of startup options. It looks from your post as if you know how to do this.
One of those choices should be to disable automatic restart on system failure. (or words very similar to that.) Use this choice to get into safe mode if you can, or into regualar windows.
Once there, go to the system restore feature and restore to a date when everything worked.
This error message is a message pointing to a piece of software (as opposed to hardware, as so many of these messages are).
The next best fix is to reinstall the OS from the ground up. this may be a major hassle, depending on the data you have on that hard drive.
Good luck
tony
I had this exact same problem happen to me with a Vostra. I tried everything you did to no avail. The only way I got it to work was to do a full reinstall of Windows XP. Even though it said I would lose everything I didn't. Since I reinstalled I never had any problems.
