Gestetner DSm515pfd Digital Copier - Printer - Scanner - Fax Logo
Posted on May 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have a gestetner DSm622sp we are getting an error code SC320.
Everett Lin
Level 3:
President:
  • Gestetner Master 990 Answers
  • Posted on May 18, 2009
Everett Lin
Gestetner Master
Level 3:
President:
Answers
990
Questions
Helped
434239
Points
3069
Hello sir; the error code you have display, that's means laser motor don't work, replace it!
What if the code is sc 990?
It is software loading related. It could be you need to reload the machine firmware, replace the hard drive or the RAM.
1helpful
I have Gestetner DSM622 SP, Iam getting Errer code SC546, can someone explain me thanks
sc546 is a fuser temperature detect error. One or both of the thermistors most likely need to be cleaned or replaced, but you will have to go into service mode to reset the code once you do that. You should contact your local service technician or Gestetner dealer, as they can easily fix that problem.
3helpful
2answers
Error code SC 542 on my Gestetner Dsm622sp
Fusing unit problem.Verify the heater lamps,thermistor and thermofuse continuity.Enter in the SP mode turn OFF the main switch,unplugged the machine wait 10 sec.,plugged and turn ON the copier.
There is a wrench displayed in red. Whats up
hi
on the screen there should be the letters ''SC'', followed by numbers.that code will tell what the problem is.
My Gestetner DSm622sp says it has a hard drive problems, codes SC870, 872 what do I do
Most machines just use regular or notebook hard drives available anywhere.
Just replace & format it inside of the copier menus.
2helpful
Error SC320
The laser motor is cooked
1helpful
Dsm622sp error code sc545
Fuser error (warm up error). Needs to be repaired, then the code can only be reset in service mode.
1helpful
Ricoh 1022 - Error SC320
USE A BIG PHILIP SCREW AND REMOVE THE 2 PCS SCREW IN LEFT SIDE AND REMOVE THE COVER WHERE THE PAPER IS EXIT. YOU SEE A BLACK BOX INSIDE, AND USE A SMALL PHILIP SCREW TO REMOVE THE 4 PCS SCREW LOCATED IN HOLE. THEN LIFT UP THE BLACK BOX AND OPEN IT. BE CAREFULL
Gestetner 3225
Ax060267,This is the part number of the polygon mirror motor , it is worn out , your machine propably makes a high reving noise aswell when it starts to print , you can go to your nearest rico or gestetner outlet and get a new motor , it sits right in the middle of the machine , sometomes it helps to remove the motor and oil it with a very thin oil , but in mostcases it is beond repair .
Top Gestetner Office Equipment & Supplies Experts
Daniel Blask
Daniel Blask
ZJ Limited
ZJ Limited
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
