It is a Kenmore Elite front loader (model #42198900). When I close the door, the door light comes on (it's getting power), but none of the buttons work to turn it on.
SOURCE: unlock the control panel to a kenmore elite front loader
to unlock the controls
select and hold drain/spin for 3 seconds until the control locked status lights turn off.
SOURCE: front load washer door won't open
There is an override switch directly below the latch under the machine on most front loaders.
SOURCE: torn seaL ON KENMORE ELITE WASHER
i have a kenmore elite washer the red lite is lit on controlles locked how do i solve this
SOURCE: Kenmore Elite HE3 front load washer door locking mechanism issue
1. Remove the lower panel under the door by loosening the three screws
under the bottom edge on the front of the washer. HINT: If you prop up
the front feet of the washer with some small blocks of wood, this will
make access to the screws much easier.
2. With the screws removed,
the lower panel should drop down then come off. If the panel sticks, a
light tap on either side will knock it loose.
3. Reach your hand up
inside the washer behind the front casing on the right-hand side. This
is where the door latch assembly is located.
4. At the bottom of the
door latch assembly is a small pull tab. This is the manual release for
the door. Pull the tab straight down and the door will come open.
Sometimes
these doors will not unlock for whatever reason. If there are no error
codes being generated, this could have just been a momentary glitch. If
you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
SOURCE: my kenmore elite oasis washer will not turn on. I
its the power button its a common prob use a soldering iron and switch it with the load sinal button this happpens as the washer alallows moisture to get on the board as its not protected it will save u a ton of money and anyone can do it
