Tomtom ONE XL GPS Logo
Posted on May 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Won't switch on
My Tomtom XL T won't switch on, i've left it charging on the computer and the green charge light comes on but it won't switch on. I,ve tried the re set button to no avail. Do i need new batteries and how do you fit them thanks michelle
  • Anonymous May 19, 2009
    Thanks for that but tried and it the screen doesn't come on, its only 16 months old but hasn't hardly been used.
Anonymous
Level 2:
  • Expert 80 Answers
  • Posted on May 18, 2009
Anonymous
Expert
Level 2:
Answers
80
Questions
Helped
26523
Points
239
Connect it to the computer, then try to switch it on by pressing the button for 1-2 seconds. If it switches on, connect to tomtom home, update, and then switch off. Disconnect, then switch on again. You may have to reset it again by pressing the button for 10-15 seconds. I onl had this problem once, after my first download from tomtom home - I think I crammed too much info into its memory!
My tomtom won"t turn on
If you have a tom tom from the GO models
they hace a reset button you can press with a pin were the mount fits.
When you plug in the charger the green light should come on to say it is chargeing.
Try the car adapter to charge the tom tom
6helpful
2answers
My tomtom charges the green light comes on I press the on button but nothing happens
I have managed to fix my TomTom one.
The problem was two fold. First the diode D8 was blown and also the power supply chip was blown.
It is a tricky job, using surface mounted components so should not be attempted by a novice but I managed it.
I have a full set of photos etc if anyone cares to try it. I figured - NOTHING to loose!! so what the heck and just went for it. Taking it apart was fun! The surface mounted IC was easy to obtain and the total cost was about £10 plus 4 hours panic labour. If anyone wants the info just let me know and I will send the photos - but no promises - it worked for me.
I figured out this ongoing problem. I purchased my TomTom One second edition 1/20/07 for $395. I was 30 days past my warranty and had the problem of unit not turning on. Green light came on when charged.
I opened my unit up and found the sw2 micro switch broken. If you press too hard on the on/off button, this will eventually happen.
I couldn't find a replacement switch so I wired my own switch and it works now.
I have it plugged into my computer green light is on, what next
Turn on the unit and than it will be recognized by the computer. The green light will light with the system in the off position as it indicates the unit is charging recieving power, just press the on button and the display should come alive.
2helpful
2answers
Green light on but will not switch on
plug in your xl via the usb cable to your computer and let it charge a few hours, then press and hold the power button for up to 15 seconds.
do not use the car or home charger to intially charge your xl. they are to maintain the battery, not a rapid charge.
let me know if you need further help.
Tom tom xl does not turn on. been on charge all night and using car charger still makes no difference
try the usb cable to your. this is the recommended method to charge a tomtom when it wont power on. for reasons unexplained by tomtom they do not recommend the car or house charges.
plug it in via the usb cable to your computer for a few hours(make sure the green light is on and nice and bright) then press and hold the power button(this could take up to 20 seconds)
bill
20helpful
My Tomtom XL won't turn on. No reset button apparent
The reset button is on the bottom of your device. On my older model XL it is just above the sd card slot. If you have the newer model XL 330 then you have to hold down the on/off switch for 20 seconds to do a reboot. If you have not used it in a while let it charge for 30 monutes before doing a reset.
Hope this helps
2answers
Tomtom not switching on
I had this problem. had it plugged in charging and then pressed the the reset and the power button at the same time for about 30-50 seconds and then after that pressed the power button and so far so good
17helpful
7answers
2answers
GPS Won't Turn On
www.batteryship.com
look up tomtom 510 - or whatever model you have
Order the battery..........comes with manual and tools to fix it
only 20.95
it works
cheaper than sending it in!!!!!!
These are genuine replacement parts!!
Laura
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
