Microwave Ovens Logo
Posted on May 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Maytag Microwage display screen is foggy
The display screen on my Maytag built-in microwage oven (showing time of day/ counting down the cook time) is foggy. Is there anything that I can do?
I think that someone cleaning it may have sprayed directly onto the screen and caused it to fog but I am not sure if that is what is wrong. All I know is that it looks foggy and is driving me crazy.
William Miller
Level 3:
  • Microwave Ovens Master 9,179 Answers
  • Posted on May 20, 2009
William Miller
Level 3:
Answers
9179
Questions
Helped
4478192
Points
21747
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you can detach the keypad connector (as per attached photo) then remove the control panel screws.
Be careful not to crack the glass display when handling it, or it's a goner.
Then you can use a soft cloth (not a paper towel) and a mild cleaner (not ammonia-based) to clean the front surface of the VFD display glass and the rear side of the clear bezel (display window) that's attached to the keypad.
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
Sharp Carousel R530BK microwave won't cook unless light pressure is kept on the door button.
There are door switches and one of them is evidently out of adjustment or the little actuator arm on it is.
2answers
The motor will not work. The interior light comes on, but the turntable does not go around. The cook time counts down, but no cooking occurs.
the turn table motor could have failed, but the counting down will be the monitor switch or a micro switch located behind control panel
Our microwave is not heating and the turntable is also not working. When I try to cook something the timer starts counting down but nothing else happens.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Microwave doesn't work
Sounds like you have a faulty control panel. I would use a meter and test the power from the control board to the magnetron and circuit board. Chances are the control panel is faulty
I have a GE microwave with the message sensor error
On GE models, "SENSOR ERROR" appears on the display when:
  • Using the sensor feature, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
  • Steam was not detected in the macimum amount of time. Use Time Cook to heat for more time.
Thanks.
Microwave GE MD JVM140K Spacemaker yr= 1994 NOHEAT, DISP/TIMER OK
Call GE answer center 1-800-626-2000
ask for tech help
Have you model # off your data plate ready.
The microwave cook time is counting down at an accelerated rate
does the clock need to be reset? check the door the latch may need replacing. also check the fuse inside the unit
My microwave oven is displaying sensor error
  • Steam was not detected in the maximum amount of time. Use Time Cook to heat for more time.
Sounds like it's running but no heat
Those symptoms are what I would expect when the controller or keypad gets wet. Tipping it is not an issue, unless that allowed the water to run into the controls more than just the wet soapy washcloth did. You may get lucky - it may dry out by itself in a few days. If not, and if careful targeting drying doesn't fix it, it will need a new keypad or controller.
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
