My tablet is not working and i typed my gmail and password but it is not working
SOURCE: do i get into my tablet trio if i don't know the password or my gmail account
you can make another account and use that.you can have as many gmail accounts as you want
SOURCE: help how do hard reset my proscan tablet plt7035 i
1. Power the Tablet off.
2. Press and hold the Volume Down button of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
5. Navigate to Erase content.
All info on tablet will be deleted but not the info in the SD card
The tablet will complete the hard reset process and reboot into a factory default state.
SOURCE: forgot the pattern to my coby tablet mid8020 4gb
Unfortunately to protect the integrity of this site, I can't give you information that may be used to access someone's tablet.
SOURCE: I need to reset my tablet to set a new pattern to
You'll need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
SOURCE: Model:v705-s tablet pattern lock.so unlock the
If you cannot unlock the tablet, look up the way to do a hard reset. You will lose all data, but it's one of your only options.
Usually the following method works:
1. Turn the tablet off.
2. Hold the volume down button.
3. Hold the power button.
This should boot you into your devices restore/update screen. If that combination does not work, volume up + power should.
4. Navigate to the wipe data/factory reset.
5. Wait for it to reload, and you're done.
