Samsung tv un 7100 to Bose SA 3
SOURCE: HI THERE I NORMALLY CONNECT MY TV DIRECTLY TO MY
See page 10 of your Owner's Manual. You need a 1/8" jack - Stereo RCA. It is not supplied, but available for purchase. I hope this was of assistance, best wishes.
SOURCE: How to connect Blu ray
hi,
do the following.
1. connect ur blue rays hdmi out to ur tvs hdmi input.
2. connct blue rays out to any one of the coaxial(aux) input of bose.
3. connect ur tvs optical audio output to optical audio input of bose
4. connect monitor out of ur bose to any one of ur av in of ur tv. connect component video to better quality .
4 . in the blue rays audio setup select audio output priority as optical/coaxial
5 . in bose set aux as digital input.
to see blue ray select hdmi of ur tv, sellect in bose in which the blue rays coaxial is connected(aux) insert disk in blue ray an watch
to see dvd in bose select tvs corresponding input, select bose to dvd . insert dvd and watch
to whach tv program set tv to corresponding mode. set bose to optical audio input mode.
ok
SOURCE: I have a Samsung 7100,
Samsung HDTVs of late have a combo component/composite video input. You can connect your Wii using the green/yellow video RCA input on the rear of the TV. For the sound, connect the white and red RCA cables to the corresponding audio inputs on the TV. Make sure not to have any cables connected to the blue and red component video inputs next to the green input. Now press SOURCE using your HDTV remote and select the AV source, navigating down or up to hilight the AV selection. Power up Wii and you should see on your HDTV.
SOURCE: need the remote code for Samsung 55" led tv 8000 series
I have the 8 series 40" led tv. The screen HAS an IR receiver. It is to the one inch left of the Samsung logo, down close to the edge of the frame. For the code i am also trying to find the right code. You may need to apply the latest system update of your V20 system.
