During the final rinse cycle washer does not drain properly. Clothes are soaking wet.
Turn timer to rinse cycle. let fill up and agitate. when it stops
agitating it should pause then start to pump water out. After about 2
minutes it should pause for 3-5 seconds then start again and spin. If
it starts the first time and never stops it will just continue to pump
but no spin. The 3-5 second pause allows the transmission to shift to
spin. If it does not do this the problem is your timer. You may need to
do this a few times to verify the problem.
If that is not the problem it is likely that you need a new clutch. You will need a technician to install a new clutch for you
I appreciate your post, Rachel Kovach!
From my understanding your Frigidaire frontload washer is not spinning the final spinning and the clothes are still wet. If you washer is overloaded it will not spin properly to release the water out of the clothes. Also, a small load will cause your washer to not spin properly. You should additionally check the drain hose to make sure it not kinked or twisted that could cause your improper draining. If all that checks properly it could be an issue with your drain pump, motor, and control panel. I would suggest consulting with a technician for proper diagnosis and repair. This will help avoid unnecessary part purchases. -Matt
