Watches Logo
A
Anonymous Posted on Dec 26, 2013
How much is a fossil mens watch model am 3423
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Dec 31, 2007
SOURCE: watch band
I just got this watch for a gift and was able to remove links myself after doing some research. It really isn't difficult if you are patient, have a little mechanical experience, and have some very basic "tools" available.
Tools:
1 push pin like you use on bulletin boards with a plastic head
1 small hammer like a tack hammer
1 pair of small pliers. Needle nose pliers would be best but I used diagonal wire cutters (be careful not to cut the link pin)
1 small block of wood
Try to pick a well lit table in a room where you will not be interrupted.
Procedure:
1. Lay the watch and band sideways on the block of wood so that a pin for the link you would like to remove is just hanging over the edge of the block and pointing down. You need the block to brace the band while you hammer lightly on the pin. Someone to hold the watch in that position would be helpful, but it can be done alone. Only try to remove pins that have an arrow on the back of the band pointing at them. It does not matter with this watch band which way you go with the pin.
2. Carefully line up the push pin point with the top of the pin.
3. Slowly, lightly and carefully hammer the plastic side of the push pin so that the pin in the link just emerges from the band on the bottom side enough so that you can grab it with the small pliers.
4. Slowly and carefully pull the pin straight out with the pliers. You can pick up the watch from the block of wood to get a better grip. Be careful not to bend the pin since you will need to replace at least one of the pins you remove.
5. Repeat steps 1 - 4 until the band is the correct length. I needed to take out 3 so I removed 2 from one side and 1 from the other side of the clasp.
6. To fasten the watch back together again, gently insert the pin back in the hole it came from it. You will probably need to use the tack hammer to make the top of the pin flush with the band.
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Jan 09, 2009
SOURCE: REMOVING LINKS FROM FOSSIL ARKITEKT MENS WATCH
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Apr 14, 2010
SOURCE: fossil JR-8748
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals. Rate me, please .
Anonymous
  • 103 Answers
  • Posted on Aug 04, 2010
SOURCE: 2 Fossil Watches wont work
fossil watches are very temperamental when it comes to there insides. did you have fossil do the band or someone else? also they sometimes have corrosion from the seals not lasting.
gemineye61
Janelle Schoonover
  • 842 Answers
  • Posted on Sep 24, 2010
SOURCE: unable to replace the back
Thank you for contacting FixYa.
This can be tricky. You may need to take to a store that has a watch press for replacing backs. Square watches are particularly tricky. I hope you were pushing the back on by pressing on sides of watch and not center as this may have warped it to not fit.
Best bet is a local repair.
Sorry.
Jewel
Fossil AM3695 Wrist band
http://www.ebay.com/itm/FOSSIL-AM3695-BIG-TIC-KALEIDO-BROWN-LEATHER-MENS-WATCH-/150793269174
My fossil watch straps as gone model is bq9254 i need latest straps model to buy
You can get straps from Fossil.
Go to "fossil.com", go to the bottom of the page and you will see a
menu, click on "customer care", and then look under "Product Info" on
the left and you will see "0rdering links and bands"
Can't set time? I feel stupid and its probably easy
Go to http://www.fossil.com/en_US/shop/customer_care/static/fossil-Instructions.html and you will find a list watch diagrams and associated pdf instruction files.
Unfortunately Fossil do not put model numbers against the diagrams, so you will have scroll thorugh the list to find the one that looks like yours and download it.
Looking for battery for Fossil Watch Style # FS4317 Watch for Men
Link
Hi mm01891,
Please browse above link for your fossil battery replacement. Kindly refer this matter to your authorized Fossil dealers.
Thank you
Fossil watch model am-4181 is it made in swiss or where
Fossil is an American company but they generally use a Myota or Epson movement (Japanese).
Need links for fossil kaleido Ll2097
Fossil will provide you with links at no charge if the model is not too old and they have the parts.
The 800 number is in your owners manual.
Top Fossil Watches Experts
john h
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Fossil Watch Expert? Answer questions, earn points and help others
