Kodak EasyShare C330 Digital Camera Logo
Posted on May 17, 2009
Memory cards wont format, says card is full
My pny and sandisk sd memory cards wont format in my kodak easyshare c330 digital camera. do u think it is the camera or the memory cards? It says "memory card is full".
  • Anonymous May 17, 2009
    i have bluetooth headset BT530 , i want listen to music on iphone,
    it does not work.
  • Anonymous Jul 06, 2013
    I format my memory card on my laptop and the card is not working on my Easyshare cx 7530
Anonymous
Level 1:
  • Contributor 34 Answers
  • Posted on Jun 09, 2009
Anonymous
Contributor
Level 1:
Answers
34
Questions
0
Helped
18068
Points
99
Is the write protection enabled on the cards?
Which size having the cards?
The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
But try an firmware upgrade.
Why download firmware version 1.07?
This firmware version improves memory card compatibility and provides general performance updates.
KODAK EASYSHARE C330 Zoom Digital Camera Firmwar
2answers
I have a Kodak EasyShare C330. I have a new memory card Kodak SD Card 128MB. When I insert it in the camera, a message displays stating memory full. When I try to format the card to the camera I received...
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
Try to format the memmory card using a card reader and the PC this should solve your problem if not you have to replace the memmory card.
2helpful
How do I format a 4MB SDHC card for this camera
"SD and MMC flash memory cards marketed by Kodak, Kingston, Sandisk, PNY and other flash-memory card manufacturers will work with the EasyShare C643. The digital camera supports standard MMC cards and SD (secure digital) cards, but not SD High-Capacity (SDHC) or SD Extended Capacity (SDXC) cards."
Read more: Compatible SD and MMC Cards for a Kodak EasyShare C643 ' eHow.com http://www.ehow.com/facts_7590028_compatible-cards-kodak-easyshare-c643.html#ixzz1BijGdWKF
15helpful
2answers
Inserted 4G memory card...says memory card is full...when I try to format the card, get filesys error e00100.....
The C330 uses MMC and SD cards. Your 4GB card is actually an SDHC card. While SDHC cards will fit into SD slots, they are electronically incompatible and won't work. You need to go with cards 2GB and smaller.
I bought a 2GB SD card for my Kodak EasyShare C330 Camera
Buy a 1GB card (or 2). The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
I have a new 2 gb dane-elec memory card and when i turn on my camera it says the memorty card is full and when i try formatting it it says filesys error e00100
Click
But try an firmware upgrade. Maybe the supporting now the 2 GB memory cards.
KODAK EASYSHARE C330 Zoom Digital Camera Firmware
4gb sandisk sdhc card
I think the C330 is not compatible with the SDHC cards.
Click
Kodac easy share c330 says memory card full, but it is a new card
Which size has the memory card? More than 1GB?
Click
2answers
New memory card and the camera says its full
try doing a format with the camera. check your manual to see how to do this with your camera. Beware, formatting will erase anything on the card. i actually had the same problem with my camera, and this worked for me. Sometimes new flash cards are not compatible off the shelf--they need to be formatted. You should have at least flash cards to be sure card is not defective. Let me know if this helps!
Hello i have the kodak easyshare c330 digital camera . i just purchase a kodak sd 2gb memory card the camera is stateing that the memory card is full can you help me with this problem please
Click
3helpful
New memory card says memory card full
The following memory cards are compatible with your Kodak EasyShare C330 Every memory card we offer is manufactured to the highest standard and carries a 2 year minimum warranty.Your Kodak EasyShare C330 accepts SD Card cards.The largest SD Card card you can use in your Kodak EasyShare C330 is 1GB
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
