just found out how to reset it Resetting the Scanner (Clearing all Memories) To reset the scanner to factory defaults, turn off the scanner. Then, while holding down 2, 9, and HOLD, turn on the scanner. All scanner memory contents are erased.just found out how to reset it Resetting the Scanner (Clearing all Memories)
You can't post conmments that contain an email address.
Check your scanner for a model number. I have found an online manual for the Uniden BCT15X from Uniden: http://info.uniden.com/twiki/bin/view/UnidenMan4/BCT15X . This model has the TrunkTracker III logo to the upper left of the LCD screen. The Uniden logo is to the lower left of the LCD screen. The model number is given above the upper right of the LCD screen. Then the Bearcat logo is below the right side of the LCD screen. Some other Uniden scanner manuals are available here: http://info.uniden.com/twiki/bin/view/UnidenMan4/UnidenScannersUsersGuides . Scroll down to the Individual Scanners section to find the links.
you may have to do a manual scan..or find out what frequency the different companies and police ,fire and airplanes use,,then you may need an outdoor scanner antenna,,the small antenna that comes with the scanner only picks up very strong signals,,,to program the scanner you may have to search online for programming info,,,,good luck
Power the scanner OFF. Press and hold the 2, 9, and HOLD keys and power the scanner ON. This procedure will clear all programmed frequencies and return the scanner to its original factory settings.
Need the manual for your scanner? You can download and print it, at no cost, here:
Resetting the scanner automatically clears all frequencies from memory and restores the unit to original factory settings. To RESET your scanner: - Power the scanner OFF. - Press and hold the 2, 9, and HOLD keys and power the scanner ON. - The word CLEAr will appear after about 3 seconds, indicating that the scanner is ready to accept new programming.
Need the manual? You can download/print it here:
http://www.uniden.com/pdf/BC92XLTom.pdf
For a comprehensive database of active frequencies in your area, visit:
Hold in the 2, 9, and HOLD keys while turning the scanner power ON. After about 3 seconds you'll see the word CLEAR, indicating that the reset is complete. NOTE: This procedure will clear/erase all the information that you have programmed into the scanner.
Need the manual for your scanner? You can download and print it here:
