Hooked up to computer, got red charging light for a min, then charging light went off. I tried the speaker, but only got intro sound, before powering off again. Hooked to charge again, no red light at all.
SOURCE: 1g mp3
that depends, when you bought the mp3 player did it come with an USB charger?
also, do you have to put batteries in it?
if A is true and B is false it is charging, else check the manual or post the actual name of the mp3player in here
SOURCE: my ipod wont charge
Do the 5 R's:
These are for Nano, but they apply to all iPods:
Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with your iPod nano. If
one of the following doesn’t help, read on for solutions to specific problems.
â Reset your iPod nano. See “General Suggestions,” below.
â Retry with a different USB port if you cannot see iPod nano in iTunes.
â Restart your computer and make sure you have the latest software updates
installed.
â Reinstall iPod and iTunes software from the latest versions on the web.
â Restore your iPod nano. See “Updating and Restoring iPod Software” on page whatever.
SOURCE: Wet itouch
DON"T TURN IT ON AGAIN UNTIL YOU KNOW IT IS COMPLETELY DRIED OUT!!!!
Sometime electroncis can be salvaged if they are not turned on again until after they are dry.
The electrolytes...(sugars, salts) can cause the electric current flowing through the device to arc accross connections causing a short. It may be too late to save your iTouch, but for the future if you can dry out the device before trying to turn it on again with a blow dryer or napkins or whatever you have handy it may save it.
Try drying it out and then turning it back on...it may or may not work as the damage may have been done already.
I hope this helps you in the future. Good Luck!
SOURCE: my archos 7 wont charge the red light comes on but
If the archos was purchased new from Archos stores they have warranty on them call tech support to find out. Have your serial number and product model number handy.
SOURCE: Sharper Image MP4 Touch Player (NEW) not charging
Mine looked like that, however, it has 2 "on" buttons. The major one on the left. says on off. Put to on. Then the upper button on the right, is actually the on off/ push and hold for 3 sec. then wait, it should come right on.
