1996 Plymouth Voyager Logo
Posted on May 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Engine light codes p0352, p0300, and p1391
Car runs fine around town for ever, once on hgwy after peroid of time looses power and bucks and misfires. Changed ignition coil b twice. Changed timing position sensor and fuel filter. still acts up. It seems to only act up for a short peroid of time on long distant trips never in town driving. I also tried Lucas fuel additive no luck. The vehicle is a 1996 plymouth voyager van with 181,000 miles 2.4 L engine. cleared codes runs beautiful around town. Plan to take a trip in June, Help!!!
Anonymous
Level 3:
  • Plymouth Master 3,640 Answers
  • Posted on Aug 30, 2009
Anonymous
Plymouth Master
Level 3:
Answers
3640
Questions
6
Helped
1676067
Points
10518
Po352 is ignition coil B primary/secondary circuit malfunction---ignition coil #2----p0300 is random /multible cylinder missfire, muti cylinder missfire detected!!
2 Related Answers
cheap repair
  • 1565 Answers
  • Posted on Nov 27, 2010
SOURCE: codes p0351, p0352, p0353 and
obdii-code-p0351-x2-704058/index4.html">http://www.jeepforum.com/forum/f13/help-obdii-code-p0351-x2-704058/index4.html
This thread basically says replace the crank position sensor and the cam position sensor. Check the wiring for the Oxy sensor(s). And if all else fails then change the PCM.
dannydoesita
  • 778 Answers
  • Posted on Oct 19, 2011
SOURCE: codes p0340 p0353 p0352 p0351 p1391
Kevin, can you give me a little more to work with? I would like year, make and model of your vehicle along with any other symtoms you may have experienced. Please get back to me with this information, and don't start replacing parts that you may not need. Waiting on your response.
I have an 05 Suzuki Forenza that has a flashing check engine light. This started on Tuesday. Had the codes looked up. Car is driving shaky and dash lights are blinking. Any ideas?
fix the anti freeze leak --before you blow a head gasket
what your codes mean
Check Engine Light On, P0300 Random Misfire Code. A random misfire means your engine is misfiring, but that the problem is not isolated to one or two cylinders. It is jumping around in a random way from one cylinder to another. A random misfire code usually means the air/fuel mixture is running lean.
What the P0700 code means. P0700 is set when the PCM detects a malfunction in the transmission control system. This malfunction causes the vehicle to set a Check Engine Light and trigger a failsafe mode. Once the failsafe mode is set it will remain until the fault is repaired or normal operation is detected.
PO133 Oxygen Sensor Circuit Slow Response (Bank1, Sensor1)
Starts up but runs rough, exhaust smells, and when you give it gas it wants to shut off.
How To Fix P0300 random misfire codes in your car ...
? 2:56
https://www.youtube.com/watch?v=OyvdWeyDHf4
Feb 5, 2010 - Uploaded by Scotty Kilmer
Scotty Kilmer, mechanic for the last 46 years and counting, shows how to fix your car if the check engine light ...
P0300 - OBD-II Trouble Code - RepairPal
repairpal.com > Encyclopedia > OBD II Codes
OBD II Fault Code. OBD II P0300. Fault Code Definition. Random, Multiple MisfireDetected. Symptoms. Check Engine Light flashing; Rough running, hesitation ...
P0300 - Check Engine Light Diagnostic Trouble Code ...
https://www.engine-light-help.com/P0300-check-engine-light.html
The misfire detection monitor, a software strategy built into the computer, is designed to detect an engine misfire. The computer can also normally identify the ...
Random-Misfire Page
www.random-misfire.com/
2001 X type 2.5 in Limp Mode and check engine light on. Scan codes P0300-302-304-306, P0 314-316and P0352-356 and P0430
The P0430 is a catalytic convert Efficiency Below Threshold Bank 2 .You have multiple misfire codes , You melted the catalytic converter . You need to take it to a ASE certified repair shop .
2007 Mercury Milan Premier V6 Misfiring
P0300 - Random multiple cylinder misfire
P0301 , 302 and 304 - Cyliners 1, 2 and 4 misfire
P0351 - Ignition coil A primary/secondary circuit malfunction
P0354 - Ignition coil D primary/secondary circuit malfunction
Dodge avenger es 1996 p0352
P0300 code is random misfire, P0352 code is ignition coil be wire malfunction, P0352 that the main problem If you are equipt with COP (coil on Plug) one of the are disconnected or at the harness to the ignition coil.
4helpful
I got several error codes on my 07 Toyota Avalon, codes P0352,P0300 and P0301-P0306. Does any one one know what could be causing it or how to repair it.
p0352
Ignition coil B primary or secondary circuit malfunction
p0300
Random/multiple cylinder misfire detected
p03001
cylinder no.1 misfire detected
p0306
cylinder no.6 misfire detected
check you coils and spark plugs
make sure they are in good shape. check you spark plug wires also.
P0300 and P0352 in a 1996 dodge caravan
Check all plugs and wires..If they are grounding out it will make it miss.Also check for vacuum leaks..Hope this helps you..Have a great day..
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
Top Plymouth Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Plymouth Expert? Answer questions, earn points and help others
