Question about Nokia 6300 Cellular Phone
Keypad not working
Water fell on my mobile(NOKIA 6300) accidentally, and my keypad has stopped working. How to solve this problem
    Master:
  • Nokia Master
  • 118 Answers
Open the Hand SET THEN GET a Normal Brush And A Nail Polish Thinner or spirit the celean the board IF not Work THEN IT Means UR KEYPAD IC is not working properly if Solved THEn plS rate me
Posted on May 17, 2009
My nokia 6300 phones back light is not working correctly. The keypad light comes on and later the screen light which goes off when you press the key pad. please advice
does your phone accidentally fell on a hard surface? if that is so, then, the board itself is loose thats why you have problems with the backlights. go to your nokia center and have it fixed. its just a minor repair.
Nov 12, 2010 | Nokia 6300 Cellular Phone
My nokia 6300 phones back light is not working correctly. The keypad light comes on and later the screen light which goes off when you press the key pad. pleas advice.
Aug 07, 2010 | Nokia 6300 Cellular Phone
Water problem with nokia 6300
my nokia 6300 has fall down in water then i switched off and on continuously at starting keypad worked then keypad stopped working after some time
Aug 03, 2010 | Nokia 6300 Cellular Phone
My nokia 6300 is workin but no lights ar coming. i ca receiv calls n msg,but cant anything,becase the light of the dsplay an keypad is nt coing.?? plz help
Frnd u can try this simple solution
  1. Go to settings
  2. security
  3. restrore default or restore factory setting
  4. now enter the security code of ur mobile (defaul is 12345)
  5. now yes
  6. i think u problem solved!
Nov 01, 2009 | Nokia 6300 Cellular Phone
Nokia 6300: I could able to use the keypad of my nokia 6300
There may be problem in mother board... Remove the panel of your mobile and clean it... If this doesn't work then therre might be some open connection on the mother board... This will be done by the nokia care people and don't take advance to correct it... Good luck...
Dec 25, 2008 | Nokia 6300 Cellular Phone
Keypad on nokia 6300 has stopped working
hi
this kind of problems occurs when the Phone Software Goes bad try to get that phone to be flashed ista process that repairmans do to give a phone a fresh firmware/Flash File
best regards
plz do rate this post as good as u can!!
Oct 06, 2008 | Nokia 6300 Cellular Phone
Nokia 6300 Cellular Phone Logo
233 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
Zaid Anarwala
Zaid Anarwala
