JVC LT-42X688 42 in. LCD HDTV Logo
A
Anonymous Posted on Dec 24, 2013
Auxilary ports not working - JVC LT-42X688 42 in. LCD HDTV
Engine auxilary water pump operation
Git car scand..cud b sensor issue
2006 chevrolet Malibu, Auxilary power port not working
I had a problem like this it was power port no good I would also check the fuse
Auxilary fuse location
whatever is not working, work backwards. alternative is to pull every fuse one at a time and see if they are good or bad.
1helpful
3answers
I need a manual for a kenwood dpx-6100md. I want to work out if I can plug in an auxilary cable.
There is an adapter for some kenwood models, CA-C1AUX adaptorat the back of HU you will find a female port to plug the adaptor,you can also make your own adaptor, visit:
http://www.pakwheels.com/forums/d-i-y-projects/22718-diy-kenwood-headunit-aux-adaptor
Hello...I have an issue with my speakers. My husband ran our speaker wires from our computer to our stereo and I can't get it to produce sound please help!!!
Be sure you plugged the plugs into the right ports on the back of the stereo.
From the computer: ensure you plugged the cables into the Auxilary Out, or Out jacks of the sound card.
On the stereo: ensure you plugged the cables into any open set of Auxilary In jacks.
Once you verify your cables are plugged in correctly, verify the input on the stereo is set properly. Set your stereo's source or input to "Auxilary" or "Auxilary 1 or 2." This allows the stereo to pull input from the cables running into the appropriately selected Auxilary source.
That should help hopefully.
If you still can't get sound, double check your computer's sound card settings and be sure the sound card is working properly.
Ipod is playing but no sound comes out of the speakers. The auxilary port doesn't work, but the radio produces sound.
I had the same problem. We had connected the power antenna lead (blue wire on Sony harness) instead of the amp on lead (blue/white on Sony harness). Check that all your connections are correct.
1helpful
I have a 1987 Ford F250 Lariat. Auxilary problems
not the cylender adj the ignition switch down on the steering colum
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
