Wolf Double Oven
I had the same problem with a Wolf L-Series double wall oven (Model DO30) and called for service (under extended warranty contract). The tech told me that the F1 error is a latch problem (you know the one that grabs and locks the door during self-clean cycles). He cleared the error using a series of "secret" button presses on the control panel and the problem cleared. Now, when it happens (which isn't very frequently), I do the same thing he did ... press "0" and "Temperature" for the oven causing the problem and hold them for about 5 seconds. The oven will ding and the display will show some diagnostics, including the error event. Press "Cook Time" and "Stop Time" while in this diagnostic mode to clear the error register, then press "Off". I've also tried to keep the area across the top of the oven opening clean (with a little degreaser), especially around the latch, and I've sprayed a bit of WD-40 into the latch periodically for lubrication and cleaning.
