Main oven door won't close fully and occasionally drops off. What is the purpose of the twoscrews abovethe hinges, please?
SOURCE: Oven Door Doesn't Completely Close
no adjustment. probably needs new hinges - hinge spring gone slack
SOURCE: belling oven door not closing fully
Hi. Yes, you will need to replace hinges, and possibly the hinge guides located inside the cookere.
SOURCE: main oven door
This comment applies to most electric ovens that have drop down doors with hinges at the bottom.
The hinges are not adjustable, and in every case the problem is caused by one or both hinge springs being weak.
The only solution, is to replace both oven door hinges together.
SOURCE: NEFF oven U1461 - The bottom oven door hinges do
If the door is a drop down door, then no adjustment is possible, the only solution is to replace both door hinges.
Please rate my solution.
Thanks.
SOURCE: Westinghouse oven does not close fully.can door
If it has a drop down door, the only solution is to replace both door hinges, if it is hinged on one side, then the door catch, or door striker could be worn, these are easily replaced,
Thanks.
Testimonial: "Thanks for your help.will try that."
