I disconnected my long distance carrier, and am just going to use my phonecard to make long distance calls from home. How can I put the MCI phonecard 800 number, and the pin number on quick-dial stored on my panasonic handset....to expedite my longdistance calls? When I use the phonebook to dial the 800 ##, I need to push another key for the pin...while on the same call....the phonebook doesn't seem available when I am already on the line.
When storing a calling card access number and your PIN in the
phonebook as one phonebook item, press {PAUSE} to add pauses after the number and PIN as necessary. Or, if stored as separate entries, during a call, press MENU, press 1 to select “Phonebook”, and scroll up or down to find the entry and press Call. Repeat to dial other numbers.
