Relic Degrade Pocket Watch Logo
P
Paul Shoulders Posted on Dec 24, 2013
How to set the time and day and date on a relic zr15701
Margaret
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 69 Answers
  • Posted on Dec 26, 2013
Margaret
Contributor
Level 1:
New Friend:
Cheetah:
Answers
69
Questions
0
Helped
21730
Points
76
Pull the crown out once to set the date. Pull it out a second time to change the time. Of course move the crown up or down and see if it will change.
2 Related Answers
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Mar 23, 2010
SOURCE: set the date on my new relic watch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all RELIC watch manuals.Rate me, please
Anonymous
  • Posted on Mar 13, 2009
SOURCE: how to set the time on relic watches
I had to go to the Sears counter to fix mine. The sales person had to use TWEEZERS to pull the serrated knob up. He had to really work at it. Once it is pulled up you can twist the knob to set the time and then push the knob back down. What a stupid design.
2answers
I have a Relic watch #ZR11960 and need two links. Are they available for purchase?
Go to a store that sells those watches and see if they can help you. Take the watch with you.
tip
HOW TO SET DAY / DATE ON AN ANALOG (STEM) WATCH
mcdevito75 here, Over Forty (40) years ago, watch manufactures added, to some of their ANALOG (wind up) and almost all of their DIGITAL (button display) watches the FEATURE of the, MONTH or DAY of the WEEK and the DATE, not only was the time of day available but also the DATE which you no longer had to go searching for, it was readily available on your wrist. The PROBLEM came with SETTING the CORRECT MONTH or DAY of the week and the DATE as some MONTHS HAD 31 DAYS rather than 30 DAYS, this meant you had to CYCLE your watch at least 62 times to get to the CORRECT DATE and mant times, when you finally did reach the CORRECT DATE, the day of the week was off, meaning more CYCLES thru the 24 hours.-------- HERE is the EASY way to SET the MONTH or DAY / DATE on your QUARTZ / MECHANICAL (STEM) watch without haveing to go thru the 24 hour cycle so many, many times. Not only is this, WEAR on your fingers, you can also damage your watch with some many cycles of the 24 hours to SET the correct MONTH or DAY / DATE. ------ HERE ARE THE BASICS,---------- Your ANALOG or STEM watch either QUARTZ or MECHANICAL should have a TWO (2) position STEM we are only familiar with the ONE (1) position we use to set the TIME, there should be TWO (2) positions to the STEM. First pull out the STEM to adjust the MONTH or DAY depending on your watches display, if your watch DISPLAYs the DAY of the week, set the DAY to one (1) DAY before the DAY you want, don"t worry about the DATE (number) yet. Once you have the MONTH or DAY set, push the STEM back into the watch, NOW with a finger nail just under the STEM (usually from the back of the stem as there is more room) gently lift the STEM to it"s first position, It may take some practice so be patient, once the STEM is in it"s first position you should be able to turn the STEM to adjust the DATE (number), if so Adust the DATE (number) to ONE (1) DATE before the DATE you want, This way your watch will be adjusted to change the DAY / DATE at the correct time. Once you have the DATE (number) adjusted to ONE (1) DATE before the DATE you want, push the STEM back into the watch, NOW pull the STEM out to adjust the time, go thru the 24 hour cycle to adjust to the correct DAY DATE (number) and time of day.------------ Your QUARTZ or MECHANICAL (stem) watch is now adjusted to the correct DAY / DATE and will change at the correct hour which is generally 12--1 AM.
on Jul 09, 2010 • Watches
4helpful
I have an eco drive and recently in trying to set the clock back to regular time, I must have done something wrong. The time is correct but the date, and day are one day forward. How do I correct this?
the crown of the watch has two clicks, pull it gently once and you can set the date and day, pull it gently again a second time and you can set the time. The proper way to set the time and date is to set first the day,date late at the actual date, then move the hands around the clock until the date change at 12 oclock this is evening, then moving the hands around until you reach the actual time. By doing so you will set the day, date and time in syn to 24 hrs change.
example: you want to change it to sat 12th 11am
set the day and date to fri 11th
then move the hands around clockwise until the day and date change at 12 oclock continue moving the hands until you reach 11am
5helpful
Need to know how to set the time on my watch
Mar 27, 2010 • Watches
1helpful
Set the date on my new Relic watch
Mar 22, 2010 • Relic watch
3helpful
Adjusting day/date on a self winding Seiko, 7S2GB
mcdevito75 here, Your stem has 1 positions to set the date easily without haveing to cycle the watch 60 times. First pull the stem out to set the day, set the day 1 day before the day you want, next, push the crown back in, NOW! Slip a finger nail just under the crown from the back as there is more room, it may take some practice so be patiernt and gently, gently lift the crown to it"s first position, once in it"s first position turn the stem and see the DATE change, set the DATE to 1 DATE before the DATE you want, NOW pull the stem out to set the day date and time of day. Your watch is set and the day date will change on time, a little past mid nite.
9helpful
2answers
How to set the time on relic watches
3helpful
Resetting time on relic watches
Press and hold the Mode button - upper left. At first, it will display the stopwatch function. Keep holding until it goes to flashing alarm set mode. Once it starts flashing, release the button and then immediately press it again and release it (do not hold it the second time). Now you are in time set mode. You can change the time, starting with the seconds, by pressing Adjust - upper right. You can move to minutes, hours, day, and date by pressing Alarm - lower right. Pressing Mode again will exit the set function.
Jul 09, 2008 • Watches
Relic watch 3 dial
Chances are they represent one of the following-
Month of the Year
Time of Day (military time)
Day of the Week
Day of the Month
It depends on what the dials have on them - usually there is some indicator (abbreviated months, numerical values, etc)
9helpful
4answers
Relic digital watch
Hold down the reset button until the hour digit starts to flash then to change the hour press the start/stop button then to change the minute press the mode button and keep pressing start/stop button until you get to your desired minute and just continue those steps through the date.
Oct 12, 2007 • Watches
Top Relic Watches Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Relic Watch Expert? Answer questions, earn points and help others
