Ok so i put some songs onto my mp3 player and theyre from burned cd's. On my mp3 player it shows up as UNKNOWN and i want to name them (if i can) But how??
You will have to take them off the player, rip your cd with media player, then BEFORE you sync them to the player, rightclick on the song, choose Advance Tag Editor and rename the song, artist, genre, then you can sync them over with title and name locked in the file.
Did you put a disk in the drive first before trying to burn? if not you do that first then Media player will detect it saying unknown media select cd or DvD then select format for songs mp3 if thats what you want and then copy your songs on to the disk. If you need more help let me know.
Mp3 players are programmed to read original & copied songs when you download music into your Mp3. if you copy an original CD (music) to your Mp3, the songs will be displayed along with all the infos of that song, i.e. artist, track #, year,etc. if you copy a CD which contains copied songs from other originals, it will display "UNKNOWN" because original CD's have their own trademarks that distinguishes them from copied CD's or any other CD for that matter...
I just had this problem as well. Find one of the files that is showing up on the MP3 player as "Unknown Artist" in your iTunes library. Right click that song/file and click "Get Info". You'll most likely find that the song is an "ACC Audio File" which happens often when you copy CDs or download from the iTunes Store. Close the info window about the song and then you can select the entire album or individual songs from your iTunes playlist that are showing up as "Unknown Artist". Once all the songs that you need are selected, right click again and select "Create MP3 Version". This will create a duplicate, however, so you'll want to go back to the main library in iTunes (or stay there if you are already there) and then remove the original "ACC" versions. You can, if you'd like, keep them on your hard drive, but you really don't need them because MP3 is the standard. From here you can remove those files from the Coby MP3 player and replace them with the new MP3 versions you have created in iTunes.
I hope this helps!
Delete songs and Format (Helps with try to delete BAD TRACKS and folders that will not delete Labeling Unknown Songs: open Windows Media Player and go to library click on artist. The sub folders will be named by the artists and the unknown songs will be in the sub that say's unknown. Click on unknown then right click on the title bar put a check next to artist and album artist. Right click song under artist or album artist or both and type in the name of the artist etc.... This change in your computers Music folders also then sync with your sansa or media player then load songs to it........
Labeling Unkown Songs: open Windows Media Player and go to libary click on artist. The sub folders will be named by the artists and the unknown songs will be in the sub that say's unknown. Click on unknown then right click on the title bar put a check next to artist and album artist. Right click song under artist or album artist or both and type in the name of the artist etc.... This change in your computers Music folders also then syc with your sansa or media player then load songs to it........
Sync to your windows media player....Labeling Unkown Songs: open Windows Media Player and go to libary click on artist. The sub folders will be named by the artists and the unknown songs will be in the sub that say's unknown. Click on unknown then right click on the title bar click Choose Columns put a check next to Genre, Rating, artist and album artist whatever you want. Right click song under artist and edit same with album artist or both and type in the name of the artist etc.... This change in your computers Music folders also then syc with your media player then load songs to it........Or drag and drop
open windows media player and goto libary click on album artist. The sub folders will be named by the artists and the unknown songs will be in the sub that say's unknown. Click on unknown then right click on the title bar put a check next to artist and album artist. Right click song under artist or album artist or both and type in the name of the artist etc.... then syc with your sansa then load songs to it........
If you're using MSC mode (moving files via explorer), I believe the player ignores the directory structure for the most part, and uses the MP3 tags. I've had very good success using Media Monkey (which is freeware) to group the songs, and then transferring from there, in MTP mode.
In the cd's the artist isn't named and if you want the artists names you need to right click with your'e mouse and click rename, type the title and then the artist.
Ok I'm not sure about this one, but try and find out if the playlist are protected cos if they are it wont show up on your player. other wise contact samsung for support (www.samsung.com)
OK thanks
