Pioneer VSX-818V-K Receiver Logo
r
ronil v deo Posted on Dec 23, 2013
How to set the region for XV DV 170 pioneer dvd player
5 Related Answers
A
Anonymous
  • Posted on Sep 08, 2007
SOURCE: DVD MALFUNCTION [MODEL PIONEER XV-DV131 (DVD/CD HOME THEATER]
I have the same problem with my XV-DV333. Search on inet and this came up: "... Pick Out One Of These! But I am unable to select any region using the remote control or the buttons on the player. What do I do? You need to get a Pioneer Service Remote. When you have it you should press: [ESC] [A.MON] [Numbers], where [Numbers] correspond to the region number you want to set. Be aware that you can only set this once, if you set the wrong region number for your area, there is no turning back. " WTF! Am I supposed to get a service remote to get this thing working again. I haven't done anything and it worked before:/
Anonymous
  • 157 Answers
  • Posted on Dec 15, 2008
SOURCE: How to multi region my Pioneer XV-DV55
Most have "hack codes" but yours is in a select group of a few that simply cant be done with a couple pushes of a button.
As far as I am aware the only way to get thesemachines to play Region 1 discs is to have them chipped. A variety of solutionsare available, and it needn't be expensive (typically £30 to £70) but youshould be aware that any internal modifications to your players wouldinvalidate the warranty. Have a look at the following web sites for moreinformation:http://www.techtronics.com/uk/shop/50-000-dvd.html
http://www.maxking.co.uk/dvdmod.htm
http://www.dvdchips.co.uk/
I know you were looking for a free solution you could do in a matter of seconds and sorry it didnt work out that way. Regardless, I hope I pointed you in the right direction and feel free to ask if you have any more question.
Happy Holidays,
TJ
Anonymous
  • Posted on Mar 09, 2009
SOURCE: I need to make PIONEER DVD player DV-310-K region free
I made it today,hurray!!!
Still need help??
rhozel2010
romy sibug
  • 269 Answers
  • Posted on Aug 17, 2009
SOURCE: pioneer dv300 dvd player - need region free unlock code
hi! try this one i hope it will work on your unit.
Remove any disc in the tray, Press the SETUP on the remote control. Move over
to GENERAL using the arrow keys; Select BASIC, Press DISPLAY - this will display
your region and firmware version. Press CONDITION/MEMORY (nothing is
displayed or changed on the screen). Press the REGION # required (i.e. 2 for
Region 2 etc). Press MENU to store.
Anonymous
  • Posted on Mar 02, 2010
SOURCE: my pioneer dvd player model dv-310 used to be able
We used a usb on the DVD and now we can't watch normal DVDs on it. We insert the DVD and the player just rejects it and opens the draw.
Need to know how to unlock the combination lock
Hiii sir
Sir my pioneer home theter region problem
Model nember -xv-dv 170
Sir help
tip
Pioneer region free code DV-340, DV-343, DV-444, DV-545
Introduction
The Px4x DVD Upgrade is an advanced modification to your DVD player, which adds extra features and enables you to get more from your machine. The upgrade supplements the DVD player and in no way harms the playback quality or removes any performance features of the DVD player.
Main Features
The DVD Upgrade adds the following features to your DVD player:
 Multiregion capability
 Macrovision disable
Players Supported
The following DVD players are supported by this version of the DVD Upgrade:
 Pioneer DV-340, Pioneer DV-343
 Pioneer DV-444
 Pioneer DV-545
Modification Details
Multiregion selection
Nearly all DVD discs on the market today are encoded with a specific "region" in mind and are made in such a way that a disc designed for "region 1" will not play on a player designed for "region 2". This is so that the Hollywood studios can control the release of titles in different geographical regions all over the world. Our upgrade allows you to select between regions 1 to 6.
Macrovision & CGMS disable
All DVD players have a system called Macrovision built in to the player, which is designed to stop the copying of DVD discs to video. However, this system can have adverse affects on some projectors. For this reason the DVD Upgrade disables Macrovision to solve any problems.
Operating Instructions
You can select the region code by remote. This region will be tried first when playing a disk.
Due to this design, the modification will work on the RCE (Regional Code Enhancement) protected DVD’s. In some cases it will be necessary to insert a conventional (non RCE protected) disc before playing a RCE protected disc. Follow the instructions as detailed bellow:
1. Turn the player on without a disc in it
2. On the remote control, press 'SETUP'
3. Use right arrow to select 'General'
4. Use down arrow to select 'Basic'
5. Press 'ENTER' on the remote control
6. Press 'Display' on the remote control
You should see the region code and OSD version that the player is set to
7. Press 'Condition/Memory'
8. Press '1', '2', '3', '4', '5' or '6' to change the region code of the player
The text will disappear
9. Press ' Display ' on the remote to control the region
10. Press 'SETUP' on the remote to exit. Play the disc
This dident work for me but mayby work for you.
on Mar 06, 2010 • Televison & Video
34helpful
4answers
Region code unlocking pioneer dv-220kv
My DV-220KV-K, which is sold as a Multi Region DVD player has locked up on me. The following message comes onto the TV screen...
(Player's Region Setting) <1> : Region <2> : Region <3> : Region <4> : Region <5> : Region <6> : Region Pick out any one of these!
The message remains on the screen ALL the time and I'm locked out of viewing anything. The remote is locked and so I cannot pick any of the region numbers!
45helpful
Pioneer DV 220-KV Need region free code please.
<1> : Region
<2> : Region
<3> : Region
<4> : Region
<5> : Region
<6> : Region
1helpful
Happy Holidays,
TJ
2answers
Unlocking DVD - Pioneer DV400 k
Hi Jetix,
If the DVD player is capable of playing other regions, you should be able to change the region setting through the menu section. If there isn't an option to change the region settings in the menu, then your DVD player is not able to play other DVDs from other regions.
Sincerely,
Agent Xiong
2answers
Pioneer xv dv505 dvd player wont play region 2
if you go to this web site http://www.regionfreedvd.net/player/pioneer.html
it will tell you how sort out your problem.
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
