Tamron 75-300mm f/4.0-5.6 LD Lens for Nikon AF Logo
Bob Billingham Posted on May 17, 2009
What magnification is a 75-300mm lens (10_20_30 times ???)
With compact cameras they say 6 times optical zoom what is a 75-300mm SLR lens in the same terminology
Anonymous
Level 1:
  • Contributor 28 Answers
  • Posted on Aug 09, 2009
Anonymous
Contributor
Level 1:
Answers
28
Questions
Helped
9761
Points
42
This lens has a zoom ratio of 4 :1 or 4 times.
Basically 75mm x 2 = 150mm
150mm x 2 = 300mm
I hope that helps,
Ian
  • Anonymous Sep 23, 2010
    actually a 300 is 6x from the normal 50mm 4x to itself.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 11, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
844
Points
I think..lens with those mm range counts here...like..if u 've got 18-50mm then its 50/18 = 2.7 zoom and if 18-300mm then 300/18 = 16.666 zoom..that is 2.7X and 16.6X...i believe !
Which is the good spotting scope for higher amount of light?
Bushnell Trophy Xtreme Spotting Scope
Overview
Bushnell Spotting Scope has extra power for extra range; its BaK-4 Porro-prism design delivers magnificent clarity in a traditional design. The multicoated optics ensure maximum light transmission for the brightest and take the images more colorful and clear. If you are searching Bushnell Scope that can be used for different activities, you should consider Bushnell Trophy Xtreme Spotting Scope Review.
The highly refractive BAK4 Porro prisms diminish spherical deviations for increased edge-to-edge sharpness and help progress depth of view. This combination of optics and coatings creates a spotting scope that produces clear, bright, highly contrasted images with the exact color transmission.
The rubber-armor structure stands up to demanding use. This scope is 100% waterproof and fog proof for wet hunting conditions. It also Comprises compact tripod with window mount, compact soft case, and waterproof hard case.
Specifications
  • Brand:Bushnell
  • Viewing Configuration:Straight
  • Magnification:16-48X
  • Power Variability:Variable
  • Objective Diameter:50 mm
  • Close Focus Distance:25 feet
  • Length:13 inches
  • Weight:31.4 ounces
  • Field of View:125-60 feet/1000 yards
  • Eye Relief/Exit Pupil:16 mm/ 3.1-1 mm
  • Optics Coatings:Fully Multi-Coated
  • Glass:BaK-4
  • Focus System:Focus Knob/Single Focus
Feature Analysis
  • Porro Prism Lens
    Though many optics producers keep on trying to transform roof prism lens, Porro prism lenses are more affordable and light-efficient. These Porro prism lenses can display images with better contrast than roof prism variations. This is how Bushnell Spotting Scope is more reliable and affordable for its high-quality performance.
  • 20-60×65 Zoom Magnification
    The wide range of magnification allows user flexibility for long-range view finding. You can observe details with 65x zoom for long range objects. But, you can still enjoy an increased field of view with 20x zoom. This is used when separating the areas for closer zoom viewing later on.
  • 65x Lens Light-Gathering Capability
    This advanced magnification lenses can light gather at long distances. The Bushnell Trophy 20-60x 65mm Waterproof Spotting Scope resolves this issue by designing 65x zoom lens in a way that brings 17% more light than most high-zoom lenses.
    If you fully read Bushnell Trophy Xtreme Spotting Scope Review, it will support you how to setting zoom for longer distances images.
  • Waterproof Construction
    When you go out in nature, this waterproof construction anticipates you about rain or even snow. It is pretty obvious that any liquid that leaks into your scope will detract from the overall image. But many people do not consider the effects of concentration on the inside of the lens.
    This spotting scope is actually water and fog proof not only for outside moisture but also prevents lens fogging from risky temperatures.
  • Fully Multi-Coated Optics
    The multi-coated lenses prevent any reflections in the glass that can delay your view. The sunlight at certain angles can cause reflections from water or wet surfaces that prevent the clear view of the images. That is why; Bushnell uses multi-coated lenses to remove any kind of reflection.
  • Well-designed Equipment
    The tripod often needs to hide from animals, and the scope cases also need to protect their insides from both jostling and the outside elements. The Bushnell Trophy XLT comes with both a hard-side case and a soft side case. The hard side case protects you from outside damage and a soft-side case protect you from a bumpy road when you are riding.
Mar 18, 2018 • The Optics
tip
Canon EOS Rebel T2i Digital SLR Camera + 28-80mm Zoom Lens + 70-300mm Zoom
Canon EOS Rebel T2i Digital SLR Camera + 28-80mm Zoom Lens + 70-300mm Zoom Lens + 16GB Memory Card + LP-E8 Battery + Case + Accessory Kit Reviews
Other products by Canon Ratting Out of 5.0 Special Offer Total New 1 Total Use 0
Read More From Here Now
Kit includes:
♦ 1) Canon EOS Rebel T2i Digital SLR Camera
♦ 2) Tamron 28-80mm Zoom Lens
♦ 3) Tamron 70-300mm Di LD Macro Zoom Lens
♦ 4) Transcend 16GB SecureDigital (SDHC) Card
♦ 5) Precision Design 1000 Deluxe SLR Pro Carrying Case
♦ 6) Spare LP-E8 High-Capacity Lithium-Ion Battery Pack
♦ 7) Precision Design USB 2.0 SD/SDHC Card Reader
♦ 8) Image Recall Digital Image Recovery Software
♦ 9) Precision Design Memory Card Storage Wallet
♦ 10) Precision Design Deluxe 6-Piece Cleaning Kit
The Canon EOS Rebel T2i features a class-leading 18.0 Megapixel Image Sensor and increased light sensitivity for low light photography, as well as an advanced HD Movie mode for gorgeous Full HD movies. Able to capture up to 3.7 frames per second, it's ready to go the minute it's picked up. Advanced Live View, a new wide-area screen, plus features like Canon's brilliant Auto Lighting Optimizer and Highlight Tone ensure brilliant photos and movies.
This set of Tamron lenses includes a 28-80mm standard zoom lens, and a 70-300mm Di LD macro zoom lens.
Take more high-resolution pictures faster with this 16GB High-Capacity SecureDigital (SDHC) memory card.
Increase your shooting capacity with this powerful LP-E8 Lithium-ion rechargeable battery.
Made from durable nylon, and outfitted with a leather reinforced handle, this multi-compartment case will easily hold your camera, lenses, flash, and accessories.
Transfer files quickly and easily with this convenient USB 2.0 SecureDigital (SD) Card Reader.
Retrieve lost or deleted images from your memory card with Image Recall Digital Image Recovery Software.
Keep multiple memory cards protected and organized with this durable storage wallet.
Technical Details - KIT INCLUDES 10 PRODUCTS -- All Brand New Items with all Manufacturer-supplied Accessories + Full USA Warranties:
- <#1> Canon EOS Rebel T2i Digital SLR Camera PLUS + <#2> Tamron 28-80mm Zoom Lens + <#3> Tamron 70-300mm Di LD Macro Zoom Lens +
- <#4> Transcend 16GB High-Capacity SecureDigital (SDHC) Card + <#5> Precision Design 1000 Deluxe SLR Pro Carrying Case +
- <#6> Spare LP-E8 High-Capacity Lithium-Ion Battery Pack + <#7> Precision Design USB 2.0 High Speed SecureDigital (SD/SDHC) Card Reader + <#8> Image Recall Digital Image Recovery Software +
- <#9> Precision Design Memory Card Storage Wallet + <#10> Precision Design Deluxe 6-Piece Lens & Digital SLR Camera Cleaning Kit
See more technical details
images Product
Read more Canon EOS Rebel T2i Digital SLR Camera + 28-80mm Zoom Lens + 70-300mm Zoom Lens + 16GB Memory Card + LP-E8 Battery + Case + Accessory Kit
on Jul 13, 2010 • Cameras
Lens size of a SVP DC- 1251
This is fixed lens camera.
Key Features Digital Zoom
8x Camera Type
Compact LCD Screen Size
2 in. Resolution
5 Megapixel Optical Zoom
Without Optical Zoom Image Quality Camera Resolution
5 Megapixel Image Sensor Type
CMOS Video Video Resolutions
640 x 480 (VGA) Lens Interchangeable Lens
Not Interchangeable Lenses Optical Zoom
Without Optical Zoom Exposure Control White Balance
Underwater (Preset) Storage Memory Type
Built-in • SD Card Built-in Memory Size
16 MB Included Features Self Timer
2 Sec. • 10 Sec. • 12 Sec. Tripod Mount
With Tripod Mount Interfaces Interface Type
USB 1.1 Power Supply Battery Type
2 x AAA Batteries Dimensions Depth
0.83 in. Height
2.3 in. Width
3.5 in. Miscellaneous UPC
859108008797 Product ID
77004823 Included Accessories
2 x AAA Batteries • USB Cable • Strap • AV Cable
2helpful
2answers
Ricoh XR-10 35mm SLR camera
stevdan,
take the screws off the bottom cover. there is a small lever pointing toward the front of camera with a black screw on it. gently move it to the left, this will release the lock lever. Now advance the lever and the shutter should fire. if not, it is not repairable. no parts
Zooming of Nikon D40 SLR Camera
You need to be more specific about which lens you've got! I'm guessing you've probably got the 18-55mm which is the most popular lens to be supplied with the kits.
From what you describe, the lens is working correctly. The problem is the maximum focal length of the lens (55mm) is not going to give you massive magnification. (Basically, the bigger the number, the more powerful the zoom.)
The sort of lenses that you can snoop on someone from half a mile away are going to be 300mm upwards.
This is one of the reasons that you can change the lens on an SLR camera. Now you might ask, if that's the case, why they don't make a 18-500mm lens. The problem is that the bigger the range of the zoom, the more the image quality suffers, so you tend to find the zoom lenses go up in a number of steps.
If you need more magnification, the only answer is to buy a more powerful lens I'm afraid :-(
Hope this helps,
Matt
Mar 21, 2008 • Cameras
If you zoom to less than 12x
The macro setting on the fz series allows you to get within a couple of centimeters of the subject and obtain focus. That is pretty close. That is too close. The camera will throw a shadow. You need some room. Most high zoom cameras (notably Olympus) have macro capabilty throughout the zoom which not only increases the magnification but also allows you (requires you) to put some distance between the lens and the subject. The panasonic fz series is different. They do not have macroability at zooms greater than 2x-3x. Beyond that there is no increase in magnification. Why? I dont know. Maybe this feature was designed on a Monday. Fortunately this can all be rectified with the use of a closeup lens. Now the fz series will react like most other high zoom cameras and do it well. The Olympus b-macro is such a lens. There are many others
Super Zoom
In addition to the optical zoom, this camera is equipped with a super zoom and digital zoom for taking telephoto and wide-angle shots. The super zoom and digital zoom cannot be used at the same time. Super zoom is used to extend the optical zoom up to 14× magnification. However, the resolution is automatically fixed at 1600 ×1200. Digital Zoom is used to extend the maximum optical zoom to approximately 40x. However, pictures taken with the digital zoom may appear grainy. Camera shake is likely to occur at these higher magnifications, please see “camera shake” question for further details on this.
Super Zoom
Difference between the D-400 Zoom and the D-450 Zoom
The D-450 Zoom is an improved version of the D-400 Zoom. Both models have the following features: •1.3 megapixel resolution •3x optical zoom lens - 2x digital telephoto •Stream-lined compact form design •Automatic focus, metering, and white balance •Built-in, pop-up electronic flash •Real-image optical viewfinder •LCD monitor •Buffered RAM memory; burst shooting •Video output to TV •12-second self-timer •8 meg SmartMedia included. Larger capacity cards available. In addition, the D-450 Zoom has the following features: •A larger buffered RAM memory permits rapid shooting (real-time shooting without having to wait for the image write) and a true sequence shooting in more quality modes: Memory Card Storage Capacity Shots Frames per second Quality Mode 10 2.0 SQ 8 0.8 HQ 4 0.8 SHQ •A new high-resolution glare-free LCD monitor screen that can be easily viewed at any angle and even in bright sunlight. The new monitor also uses less power •Automatic ISO adjustment from ISO 160 to 640. Manually selectable ISO 160, 320, and 640 •New Slow-Synchronization flash mode which enables the use of the flash on shots requiring long exposure (such as night time photography) •Image playback now includes an easier to use index mode of 4, 9, or 16 images. A 3x magnification inspection mode allows easy viewing of image detail •Overall power efficiency has been improved. 1.5 to 2 times more battery life compared to the D-400 Zoom •D-450 Zoom comes in a Champagne Gold finish NOTE: The D-450 Zoom digital camera does not include the Olympus FlashPath floppy disk adapter (which was included with the D-400 Zoom). The FlashPath adapter is available as a separate accessory.
Differences between Optical Zoom and Digital Zoom
When you change the focal length of a zoom lens, the subject is magnified. Optical zoom replicates the zoom of a 35mm camera. Digital zoom takes a portion of the image's data and displays it at full size, producing a magnification of the original image, similar to the effect of using a telephoto lens. However, the process is different from the magnification produced using the camera's optical zoom, and the stronger the digital zoom, the more the image will degrade.
Top Tamron Cameras Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Tamron Camera Expert? Answer questions, earn points and help others
