What parts do i need to replace
Parts can be ordered form www.toolpartsdirect.com. Air regulator should be adjusted with very little air pressure in the system. If you are adjusting the regulator with full tank pressure, you are overworking the plastic parts within. Over time, water will rust parts inside of the regulator. I would order the complete regulator. You could also remove the regulator part of the manafold and use full pressure to the quick connects. If you need to regulate the air pressure down a bit, purchase a universal regulator and install quick connect fittings. Male fitting to air in and female fitting to discharge port. Install this regulator to one of the quick connect fitting on the a/c. Good luck
