You will require 4 heavy gauge 1/4" speaker cables in order to connect all 4 cabinets to the Behringer power amp. Usually two longer ones from the power amp to the sub woofer cabs. Then two short ones from the second "thru" jack to the upper 15" cabs. Remember the entire audio frequency range is going to all four speakers. Sometimes you will have problems balancing the low frequency levels between all four cabs depending on the loading of each. A more desirable way to do this is with a bi-amped arrangement. This way two seprate amps are used for the subs and 15" cabs and you control them independantly.
SOURCE: what kind of fuse does peavey pr15 passive use
Here is a site that has PR15 fuses... shown as a 2.1 amp. Very strange value, and it must strictly be for the tweeter portion as 2.1 amps is nothing for a speaker... I don't know that I believe this site.
If you have a Guitar Center near you, inquire there.
