Nikon Coolpix S3000 Digital Camera Logo
A
Anonymous Posted on Dec 22, 2013
Camera will not turn off
Tried to transfer photos to computer - camera switched on but will not switch off and will not take photographs
5 Related Answers
CremeStout
Larry
  • 126 Answers
  • Posted on Nov 29, 2007
SOURCE: camera dead
You have created a locked USB port internal on your camera.
I would try removing all batteries,media.
Reinstall batteries, let them recharge.
DONOT put media in just yet.
Then power on.
See if camera says no media installed. If no power on then you might have fried the internal POST for your camera.
If it says no media power down, try installing media, see if it recognizes media. If NOTrecognized then try new media from camera store sample, if none available. If still nothing (bad)
freetek
Steve Allison
  • 5569 Answers
  • Posted on Apr 19, 2009
SOURCE: photos being transferred to computer lost connection during transfer. Now no photos show in the queue
A good reason to use the 'copy' function whle transferring. Doing this will preserve the pix in the camera memory until you are sure they actually arrived on your computer.
If you have a card drive, you might pull your memory card and plug it in directly to see what might remain there. It may come up as only a 'removable drive' that you can address as if it was any other.
Anonymous
  • Posted on Apr 24, 2009
SOURCE: camera not recognised on computer so unable to transfer photos to
Try reloading drivers software that came with the camera.
Anonymous
  • Posted on May 27, 2009
SOURCE: Can´t transfer photos to computer
i need the software that will transfer the pictures from coolpix 3700 to computer
MaMa Jams
Laura Jambon
  • 94 Answers
  • Posted on Jan 30, 2010
SOURCE: I can't transfer my photos. Transfer doesn't come
Make sure camera is off. After you plug your camera into your computer turn camera on. This should open the program for you. If not, right click on START button, go to EXPLORE, find your camera in the list. right click on camera, go to OPEN WITH. Select the program you want to use and VIOLA, you're in.
Hope this info was helpful to you. Good Luck!
How to transfer photos from canon EOS rebel t5 TO laptop
switch off camera , connect to laptop with usb cable, turn on camera, drop down window will ask what to do with photos. If no window , click on start, click on computer, your camera should as a drive , right click and click open on the drop down window .
How do i access my photographs
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER
If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Then you can view them on the computer.
Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Apr 06, 2013 • Cameras
Camera turns itself off when trying to trasfer pictures to my computer
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Not able to download disk on to comp
Do you mean you have connected your camera to the computer with the USB cable, but the photographs can't be transferred to the computer?
Then try one of the following solutions:
1) Go to My Computer > Select the photo camera device > Right click > Explore > Copy all files (photographs) as from any normal folder.
2) Take out your SD memory card, put it the USB card reader: http://www.amazon.com/b?ie=UTF8&node=516872 If you have a modern laptop - it will have a special card reader slot. Go to My Computer > Select the SD card > Right click > Explore > Copy all files (photographs) as from any normal folder.
3) Try Picasa (picasa.google.com), install, run and go to File > Import to get pictures with this program.
Photograph Transfer. Unable to transfer from VAIO
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Transferring photos from digital to photo frame- How to? Please
If you need to transfer to your computer just connect the USB cable from the camera to the computer, switch the camera on, turn the dial to View and Voila! A connect icon appears on the camera screen. Follow instructions on screen to download photos; develop if necessary. Presumably you will then be able to download the jpegs to your photo frame from your computer.
Can I view photos on my iPod photo/"Color"? nano?
Depending on the model, to view photos on your iPod photo/"Color", you either need to import photographs using Apple's iPod Camera Connector, or transfer images from your computer through iTunes 4.7 or higher to the iPod. For the current iPod U2 Special Edition "Color", iPod "Color" (20.0 GB), the version of the iPod photo (60 GB) introduced on February 23, 2005 and renamed iPod "Color" (60 GB) on June 28, 2005, as well as the discontinued iPod photo (30 GB), the simplest way to transfer photos from many digital cameras to your iPod is to purchase and use Apple's iPod Camera Connector (US$29). This device simply allows you to directly connect a digital camera to the camera connector and in turn connect the camera connector to the iPod "dock" port. Photos imported using the iPod Camera Connector are immediately viewable, with the exception of RAW format images and video clips. However, photos imported using the iPod Camera Connector cannot be immediately viewed as a slideshow with transitions. On versions of the iPod photo (40 GB, 60 GB) released prior to February 23, 2005, photos transferred directly from a digital camera using an iPod-compatible media reader are not immediately viewable, but photos transferred through iTunes 4.7 or higher, which converts photos into a "thumbnail" format, can be viewed on the iPod photo itself or displayed using the iPod photo connected to a TV or projector. The iPod nano, introduced September 7, 2005, can display photographs on the internal display "loaded" from a computer, but as it lacks video out, it cannot display photographs on a television or projector. The iPod nano also does not support the iPod Camera Connector or third-party solutions, so photos cannot be transferred from a camera. For information regarding the iPod nano and accessory compatibility, please refer to Apple Support
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
