Hi, Our Zanussi ZWF1421 started beeping yesterday mid-cycle, I went into the kitchen and the 'end' light was flashing and beeping. I pressed start again but nothing happened. Now when we pick a cycle and press start, nothing happens except it starts humming/buzzing? I read somewhere on this forum to press and hold the start/pause and another button, which I did and it beeps twice then pauses? I just can't seem to find out what that means! My Dad reckons it's the pump - does it sound like that is likely to be correct and if so, is it repairable?! It's obviously just before Christmas and we really can't afford to buy a new one :( Any help really appreciated! Thanks :)
SOURCE: Zanussi err problem
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
SOURCE: hi my zanussi zwf1432s stopped halfway through
Hello Paula,
Do not know how many flashes but 1green/1red = 11 water pressure low.
2green/1red = 21 blocked filter or pump fault.
You would be best firstly checking the filter and make sure it is clean and pump turns.with water drained and filter out shine torch into filter put on spin/drain and see if pump blade spins if not then try and turn with long screwdriver to free out any debris then refit filter and check for leaks and try donnt fill fully until you are happy it can drain water.
Hope I was of some help.
Good Luck
SOURCE: Hi!
I've had the same problem. I removed the top lit and found some pressure
transmitter and a pressure switch. I suspect that the pressure
transmitter is use for measuring the waterlevel in the machine. I think
the membrane loses its flexibility over the years.
I pulled of the hose from the transmitter and blowed and sucked a few
times on the transmitter. After doing this the machine washes without a
problem since then.
Hope it helps for you.
SOURCE: ZANUSSI FLE1015W,THE problem i have
Have you selected a program?
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
