I also have figured out if you push the power button while you plug it in sometimes helps it restart.I also have figured out if you push the power button while you plug it in sometimes helps it restart.
You can't post conmments that contain an email address.
you might have to do a hard reset by holding the volume up and power button at the same time then reset it but you will lose personal info unless theres a reboot option in the firmware menu when doing this heres a bit on the site about it https://support.sprint.com/support/tutorial/Perform-a-hardware-factory-reset-Slate-8-Tablet/WScenario_542_61280_771_en_396-dvc9560006prd
try holding the volume up button and then power it on ( keeping the volume up button pressed in ) if you get a menu just click restart tablet. you will loose everything if you reset with pin but some tablets have a hard reboot option like i described but it wont delete anything
Attach to power charger. Try hard shut down then try reboot all while connected. Then at that point you should see your keyboard again once o/s is back up.
Please make sure the tablet is charged for at least 4-6 hours. Also, make sure the correct button is being used, oftentimes we hear the back or home button has been used in error. If the issue persists, you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on. Support Troubleshooting Guide
Press and hold the power button for about 20 seconds. It should hard reset. If it still get stuck. Power it off. Press the power button then press and hold the power + silver back button for about 8 seconds. You should get a menu that will allow you to factory reset the tablet.
If they are hard buttons, meaning not (software) then yes. The digitizers are usually pretty expensive $100+ and you will need tools to open the tablet. ifixit.com has tools. You may need to get the parts from ebay though.
