Homelite ZR10926 16 Chain Saw Logo
A
Anonymous Posted on Dec 21, 2013
What is the compression on homelite 3816 chainsaw
3 Related Answers
Anonymous
  • 2220 Answers
  • Posted on Mar 13, 2010
SOURCE: set carb homelite chainsaw mod ut 10939
No response to CR.
Anonymous
  • 3 Answers
  • Posted on Jul 07, 2010
SOURCE: homelite ut10560 chainsaw good compression, good
check your fuel lines for cracks carb screen (if it has one) or jets might be clogged , also, I have a husk 350, fired only with gas in the carb, would not run at all just start and off. would not fire at all without doing that. the head bolts were little lose. I tightened them down put it back together, and that was the problem.
Anonymous
  • 4088 Answers
  • Posted on Jul 14, 2010
SOURCE: Homelite 10540 chainsaw 35CC chainsaw won't start when hot
Go to: http://www.drystacked com for a 12 page article on Walbro carburetor theory and troubleshooting. Check particularly, the position of the gasket in the lower chamber. Check the spark plug for blue, snappy spark when the engine is hot. If ok, place a small amount of fuel mix in the cylinder and try for start. If it pops several times, look to the fuel system. Check the fuel filter, air filter, and muffler for plugging. Does the primer bulb fill with fuel after several pumps? Check the fuel lines for decay or other damage. When the engine is hot, try not using the choke, but set the fast idle. Hope some of this helps!
On a 3816 C homelite chainsaw what would cause it to run only while the coke was on
Run screw on carburetor is too lean, fuel line in tank is partially plugged or a bad carburetor.
Troubleshooting chainsaw
Sadly, the 3816 is not designed for larger timber. 38cc is only for smaller limbs, As a general rule also the largest timber to cut should only be 2/3 of the length of the bar
Poulan 3816, back fires through carburator, wont start.
water in the gas or carb needs to be removed and taken apart and cleaned
Homelite chainsaw runs rough and clunking sound
How is the compression? Pull the start cord without trying to start and you will be able to feel the compression.
Mac 3816 chain oiler doesn't work
I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
HOMELITE 27AV CHAINSAW WILL NOT START. CLEANED CARB, PLUG GETS GOOD SPARK. TRIED EVERYTHING.
Hi chuckbjr44,
Have you checked the compression ?The way to do that is take the plug out and ground the plug wire by tying it out of the way so that it touches on some metal .Use a compression gauge while a friend pulls the rope.It sounds like rings to me. Thank you for using Fix Ya. ps you can a local repair shop for the specs on the right compression for your saw.
Homelite 27av chainsaw won't start. Fuel, Filter Sparkplug ok !
Full choke,
Pull cord.
Put to run,
press compression in if popped.
Pull til engine starts or guns,
once engine guns push in compression and pull once to three times til start.
Apr 12, 2010 • Garden
1helpful
What is the factory specification for engine compression on Homelite super XL
You may find this interesting:
http://www.arboristsite.com/showthread.php?t=123067&highlight=Super+xl
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
A large international collection of chainsaw enthusiasts with a few retailers and mechanics thrown in.
There are some good discussions about compression testers, Lakeside53 was one of the best mechanics there but has moved on. His discussions continue. If he said it it, is so! Join in. You and your saw will be welcome. For specifications SawTroll if queried might have the factory rated compression. He is the specification authority. HTH
Lou
Top Homelite Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Homelite Garden Expert? Answer questions, earn points and help others
