The motor locked up because the thread is tangled.
Solution:
Remove the tangled thread before continuing the operation.
Clean the bobbin case to remove the tangled thread.
After cleaning the bobbin case, insert the bobbin case properly.
If the needle is bent or broken, replace the needle.
Then, thread the upper thread properly, and continue the operation.
I also have an e6 problem on my machine and it was smoking! What do I do?
try these things
new needle
rethread machine--presser foot & needle to highest position
keep a check on the thread take up lever, when the top thread come
off the thread take up lever it can also make the machine jam
SOURCE: I am using my Brother
What kind of thread are you trying to use? Is it a decent fresh thread? If, it is old, throw it out and buy some fresh quality thread. Usually, cheap thread is the problem.
SOURCE: Very inexperienced sewer! How do I thread it?
The way I solved this problem was to take a break! When I resumed I was more patient and found that I wasn't doing the bobbin right. I took my time and got it right this time....hooray!
