Hi 1.The flash onthis modelCanonworks onlyif you manuallyraise the flash.Itdoes not riseautomatically,and is onlyon the raisedflash. 2.Flashon the modulehas a switch- itsometimesfails andthenflash "does not understand"that she had toget involved. 3.Not workingflashcapacitorcharging circuit- usually afterany water 4.Flashlampis not working- usuallyafter a lightblow 5.Commanddoes not work(a piececircuit)from the processorto lightthe lampflashes -aftera blow orhitthe water.
If youfollow steps 1- Raise theflash and thecamera is turned onin the menumode - "shoot with the flash" -but yourflashdoes not work- the restcan fixbrokenonlyengineerto repair.
the signal indicator lights are suppose to flash in perticular time interval which is connected to a timer relay when the light flashes faster that means the other light is not working and the relay is getting double the current and moving faster so check the other light either the bulb is fuse or the current is not reaching up to the bulb
if you are using flash lights on the art work, please follow the following steps
turn off your flash in cam since it bypasses the external flash and makes the picture look different.
turn your light settings to either automatic or "flash light or arc light".but do not set them to incandescent light!!!
turn your macro to on status if you are going to take a close up shots, but please note that close up shots work great in natural sunlight than at flash lights...
i just replace the lamp, and don't have any light coming from lens,starting green (after a few seconds,green become to flash), then turning on orange and lamp light flashing...please i need help, fan working perfect...i don't have a remote,is a problem, or not
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced. Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience. Thank You.
