I use windows xp sp3 i connect my memory card to computer it can not open it shows this disk needs formate i formate memory card but it shows windows unable to formate what to do to repair my sd memory card ?
Have you found out why your SD memory card needs to be formatted? Have checked how it shows on your PC? Is it in RAW file system or virus infected or logically damaged? Honestly, no matter why it becomes unformatted on your PC, the simple formatting process could help remove this not formatted error with ease. However, before any formatting process there, also remember to back up everything inside well in case of data loss troubles.
If this SD memory card is still not able to be formatted, also download some format tool to take chances. Perhaps, a new memory card is also could be a better choice.
You will need special formatting software from the disk maker. Windows XP will not normally format a sd memory card.
SOURCE: my 4gb microSd sandisk is infected and cannot be
It supposes to have a tiny lock/switch on the side. Move it up or down to turn off/on the write protection.
SOURCE: cannot delete in transcend micro sd 2gb memory card.
hi if you look on one side of the disk you will see a little white switch ( very small ) move this in the opposite direction of where it is and that should sort you out....hope this helps please vote thanks
SOURCE: unable to format 2GB sand disk memory card
Hi Sir ^^
SOURCE: how to format my corrupted
If you a using a card reader that plugs into your PC and it STILL doesn't read from the card, this means that the card itself is defective and needs to replaced. You CAN try using another card reader to see if that helps.
Hope this helps. :)
click start click to open on my computer you should see your 2gb Usb drive E: or something
right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions
make sure all 3 boxes are ticked full control change and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your 2gb Usb Drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
click start click on my computer to open you should see your drive
right click then select format
another way
click start control panel administration tools computer management disk management right
right click on your usb drive select format
hope this helps
Start up a computer with
Windows XP, Vista, or Windows 7. Insert the SD card into an external memory
card reader or into the computer's built in card reader. If it the first time a
SD card has been inserted into the computer, Windows will recognize the SD card
and automatically install drivers to read the memory card.
Go to the computer
view by clicking on the windows start menu icon in the bottom right corner of
the computer. In Windows 7 and Vista click "Computer". In Windows XP
click "My Computer"
Right click on the
SD drive under the computer heading. A dialog box with different options for
the drive will appear. Click on "Format" to bring up the formatting
dialog box.
Select the type of
formatting (also known as file system format). In Windows XP or Vista there are
several choices including FAT, FAT 32, and NTFS. In Windows 7 there is an added
choice called exFAT formatting. This is an improved FAT formatting type with improved
meta data capabilities. Choose the formatting type, name if the drive if
desired, check or uncheck the "quick format" option, and press the
"Start" button. When the SD card format is
complete Windows will provide a notification.
If this answer helpful please vote me. Good luck. Thanks for using FixYa
